Author Topic: PE175C/N piston  (Read 6350 times)
PE175C/N piston
« on: July 06, 2016, 01:09:49 pm »
can the PE175T,X and on pistons be used in the PE175C/N the part numbers are different?
thanks
Offline pecrazy
Re: PE175C/N piston
« Reply #1 on: July 06, 2016, 03:41:46 pm »
I have a genuine Suzuki piston to suit PE175 c/n, or so it says on the box. Part No. 12110-41503-050    .50 over if you need one.
Re: PE175C/N piston
« Reply #2 on: July 08, 2016, 01:30:05 pm »
pm sent
Re: PE175C/N piston
« Reply #3 on: July 08, 2016, 02:13:46 pm »
thanks
Yes. Apparently there's a difference in the transfer cut-outs in the skirt, but I can't tell you what they are - I rebuilt The Wife's N model using a later model piston, but the worn out piston was already the later type...
Re: PE175C/N piston
« Reply #4 on: July 08, 2016, 02:55:35 pm »
thanx Nathan
I know the later rings fit and they have discontinued the 1978/79 pistons so all good to go with PE175T(later type) pistons.
feel much better now. cheers
Re: PE175C/N piston
« Reply #5 on: August 06, 2016, 12:32:21 pm »
A big thanx pecrazy, the piston is a pearler, very professional, couldn't ask for better service and price
cheers pete
