Author Topic: Piston window radius  (Read 3664 times)
« on: June 27, 2016, 03:18:54 pm »
Finally got the holes & slot put into the back of my CZ piston to Charlie Richardson's provided sketch for running a reed valve & would like to know how big to make the radius around the holes as I've never had anything to do with modifying pistons
At the moment I've basically broken the sharp edge off both the inside & outside of the holes with needle files to .5-1 mm wide, is this enough to remove to the stresses from having sharp edges
Initial work
Offline Momus
Re: Piston window radius
« Reply #1 on: June 27, 2016, 05:19:21 pm »
What you've done with the radius looks good to me; very similar to production Jap windows.
If you love it, lube it.
« Reply #2 on: June 27, 2016, 07:50:11 pm »
Haven't compared it to the original piston that came out of my TY250 but I will tomorrow.
Once the cylinder is back from having the exhaust port bored round to fit a new spigot I'll be looking at pulling the motor down & fitting the new stuff to it. I may buy another carb & fit the jetting kit to it so I know everything is brand new & can put the piston port stuff to 1 side together
Offline William Doe
« Reply #3 on: June 28, 2016, 05:20:46 am »
Quote "I may buy another carb & fit the jetting kit to it so I know everything is brand new & can put the piston port stuff to 1 side together"
That is good thinking Tony makes good sense  :)
