Author Topic: 74 YZ250A crank seals wanted  (Read 11761 times)
Offline micko
« on: June 14, 2016, 04:50:40 pm »
before I go searching, does anyone know a source for these ?
Re: 74 YZ250A crank seals wanted
« Reply #1 on: June 14, 2016, 04:58:29 pm »
Mick - not sure if they have them but the best range of parts yet I have seen are www.nwvcp.com and www.yamatopdog.com - usually expensive but see how you go.  Yamatopdog - Speed and Sport - list one and contact them for the other which usually means they have an alternative.
« Reply #2 on: June 14, 2016, 05:25:46 pm »
Check that they are not the same as DT1 seals first , far cheaper .
« Reply #3 on: June 14, 2016, 06:26:18 pm »
Just checked the parts book the numbers are the same and sizes SW 30-72-10 and SW 42-72-10 . Iain
« Reply #4 on: June 14, 2016, 07:23:25 pm »
and that is what S & S would probably offer as an alternative
thanks Iain.
Hey - not around Hobart much are you????
Offline micko
« Reply #5 on: June 14, 2016, 07:37:11 pm »
yep, not available from Yamaha anymore and not sure about NOS seals after all these years.
« Reply #6 on: June 14, 2016, 09:52:33 pm »
don't know that they demanded enough to have someone making new ones now Mick - unless by some miracle a late model set fit????
Offline Viper666
    • Ballarat Rovers MCC
« Reply #7 on: June 14, 2016, 10:32:38 pm »
This Yamaha 93103-30044-00 OIL SEAL,SW-TYPE is used on these models and components:
1968 DT1 CRANK SHAFT
1969 DT1B CRANK & PISTON
1969 DT1S CRANK & PISTON
1970 DT1C CRANK & PISTON
1970 DT1CMX CRANK & PISTON
1970 RT1 CRANK & PISTON
1970 RT1M CRANK & PISTON
1971 DT1E CRANK & PISTON
1971 DT1MX CRANK & PISTON
1971 RT1B CRANK & PISTON
1971 RT1MX CRANK & PISTON
1972 DT2 CRANK PISTON
1972 DT2MX CRANK - PISTON
1973 DT3 CRANK PISTON
1973 RT3 CRANK PISTON
1974 YZ250A CRANK PISTON
1974 YZ360A CRANK PISTON
1975 YZ250B CRANK - PISTON
1975 YZ360B CRANK - PISTON
This Yamaha 93103-42045-00 OIL SEAL,SW-TYPE is used on these models and components:
Offline micko
« Reply #8 on: June 14, 2016, 11:19:27 pm »
Thanks for the info
Offline Viper666
« Reply #9 on: June 15, 2016, 09:13:25 am »
The last time I rebuilt my sons YZ125 (2006 model) I got all the seals from a bearing joint & had no problems whatsoever & a 3rd the price of genuine.
Remember NOS ones will be up to 40 years old & may fail prematurely due to being brittle.
I had one seal fail on my YZ250 1979 (Stator side) & needed a quick fix & again used one from the bearing place without issues.
That said they may not have the exact size thickness wise. Meaning they will most likely have ones that have the correct inner & outer diameter but smaller in width. I have used these in various location & they still perform as expected but you just have to be careful when seating them.
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #10 on: June 15, 2016, 01:00:52 pm »
ebay...
there's a seller in the US that does seals for the
Dt/Rt1,2 & 3...
i think they're all the same seals
"flat bickie"
« Reply #11 on: June 20, 2016, 02:11:15 pm »
All the same seals, i get them in packs form a guy in Canada there like $20 IIRC
