Author Topic: CD12 items for sale  (Read 10210 times)
Offline Husky500evo
CD12 items for sale
« on: June 03, 2016, 05:09:00 pm »
I am thinking of bringing some stuff to CD12, to try and sell . But I don't really want to transport it a long way , to only bring it home again , so I thought I would put up a list and only bring the bits that there is some interest in . I can put up some pictures if required , in a few days, when I get home from work.
'83 KDX 200 bottom end (no clutch , primary gear or ignition ) . Crank and cases seem ok and gearbox turns over . $150 .
'84 KX125 pipe $140 .
2 x '80 PE250 pipes . One is mint $240 and the other is pretty good , but with a few dents $140 .
'80 YZ250G back wheel , fitted with 17" gold Sun rim in very good condition $150 .
'80 YZ250/465 swingarm $50 .
YZ "Z" spoke rear hub $40 .
'74 Maico 250 cylinder .060 " oversize $150 . Matching head $50 .
'82 XR500 cylinders , std bore $100 each .
XR600 cylinder with cracked sleeve $40 .
XR600 head $160 .
Maico AW clutch cover $100 .
« Last Edit: June 08, 2016, 11:17:13 am by Husky500evo »
Re: CD12 items for sale
« Reply #1 on: June 03, 2016, 05:36:41 pm »
I paid for my entire weekend  and made a bit of drinking silver from moving parts on that i was never going to get around to using. Also helped a guy out with a brake cam who lost one  on the track. bring what you can someone will want something.
Offline Husky500evo
« Reply #2 on: June 03, 2016, 07:56:38 pm »
Yeah Pokey, I think I will just bring the smaller items and leave the bulkier stuff at home , unless someone is interested.
Offline Jumbo J
« Reply #3 on: June 07, 2016, 06:56:50 pm »
Do you know if the 74 Barrel will bolt straight on the a 77 AW400?
Offline Ekka
  • Go hard or go home
« Reply #4 on: June 07, 2016, 06:59:53 pm »
What model is the xr 600 head
Offline Husky500evo
« Reply #5 on: June 07, 2016, 09:21:10 pm »
I am fairly sure that a '74 Maico top end will bolt on to later cases , up till '81 cases when they changed the stud spacing . Someone will correct me if I am wrong . The '74 models had mild porting though , because they had 4 speed transmissions and needed a wider spread of power.
Not sure of the model of the XR600 head , although it looks like a later one that suits a single carb manifold. I will take some pics and post them up .
« Last Edit: June 07, 2016, 09:34:23 pm by Husky500evo »
Offline Husky500evo
« Reply #6 on: June 07, 2016, 09:29:29 pm »
Offline Husky500evo
« Reply #7 on: June 07, 2016, 09:33:28 pm »
Offline Paulos
« Reply #8 on: June 07, 2016, 09:46:07 pm »
Yz125e 78 roller, inc seat  $100
Cr125 87 seat $40
Offline steve234
« Reply #9 on: June 08, 2016, 06:25:10 am »
Paulos, have you got pictures of the 78 yz125 roller?
Steve
Bultaco M106 Astro
Wanted: Dirt track bikes / parts / info
Offline Paulos
« Reply #10 on: June 08, 2016, 09:29:00 am »
Steve
The pics won't be anything special, its hanging up in my shed at the moment.  Let me know your mobile number and I'll text them to you.  Cheers
Offline Husky500evo
« Reply #11 on: June 08, 2016, 11:16:02 am »
'74 Maico 250 top end .
