Author Topic: Maico gearbox parts  (Read 6224 times)
Offline Husabergpete
Maico gearbox parts
« on: May 30, 2016, 07:23:03 am »
Guys at yesterdays race meeting I lost the following parts off my 1977 AW 250.
The sit on top of the gearbox beside the carby and fit into the gear selector plate. There is like a hollow dome nun/screw that pushes the spring down onto a pin that fits into the selector plate indents. (stops the 1000 false neutrals)
1/  Pin pawl - part # 3415
2/  Compression spring - part # 3422
3/ Tension spring holder screw - part # 3417
Located in Wollongong 80 ks south of Sydney
Pete
Re: Maico gearbox parts
« Reply #1 on: May 30, 2016, 09:50:48 am »
There you go, click on the pic for Ebay link
Offline bazza
« Reply #2 on: May 30, 2016, 04:58:45 pm »
Chippys maico
support Auzie company
Embrace patina
« Reply #3 on: May 30, 2016, 05:44:23 pm »
Well Bazza, obviously he has already rang Chippy(Paul) or the other Paul(Stackers) first  ::)
Unless Pete was hoping for a santa ::)
(Paul)  is Chippy direct link :)
« Reply #4 on: May 30, 2016, 06:13:29 pm »
Gents thanks for the help. As it turns out I am a bit out of the loop with Pauls business. I know Paul as he helped me with the original build about 4 years ago. I given him a call and left a message through the business web site.
Need to get a wriggle on as Bathurst meeting just around the corner.
Once again thanks.
Pete
« Reply #5 on: May 31, 2016, 07:25:42 am »
Will a 1978 400 pin nut and spring fit. One on ebay now
ta
Pete
« Reply #6 on: May 31, 2016, 11:23:32 am »
ta
Pete
I think you would be able to compensate? and get the 78 one to work, but they are different Pete(the 78 has a much longer thread for a start).
I can garantee that the pic/Ebay link I put up is most definitely the correct one.
I see it has been sold now. I hope its on its way to the Gong. Cheers.
« Reply #7 on: June 01, 2016, 06:57:40 am »
Hi Mick,
Yes I hit the Ebay button on those gear box bits. there was about 20 hours to go and started to think I wouldn't find anything locally.
I have been in touch with Chippy over the phone. He was on the hunt for me too. Top hand that Chippy. Wasn't aware he had kicked up Maicos at Chippys.
Over the years he has helped both myself and Reg with our AW 250 restos. Well before it was a business
Thanks for help
Pete
