Author Topic: 1982 DR250 chain tension  (Read 5805 times)
Offline bazza
« on: May 20, 2016, 02:18:14 pm »
Think cut chain to short.any one know recommended chain slack?
Embrace patina
Offline mick25
  • Hunter valley NSW
Re: 1982 DR250 chain tension
« Reply #1 on: May 20, 2016, 03:10:37 pm »
when the swingarm is in a straight line with the centre of the front cog and swingarm pivot centre that's the tightest part of the chain I make all my bikes 15mm  slack.
« Last Edit: May 20, 2016, 03:13:13 pm by mick25 »
« Reply #2 on: May 20, 2016, 06:48:57 pm »
1 to 1.5 cm sounds right.
if you've bashed the rear wheel up against the front edge of the axle slots and you still cant join the chain...its too short.
if you've joined it and leaning on the seat it still tight, its still too tight. risk pulling the countershaft bearing apart.
if your stuck, get another joiner and put another link in
« Reply #3 on: May 20, 2016, 06:59:59 pm »
A loose chain has never snapped but a tight one has.
Offline Doc
« Reply #4 on: May 20, 2016, 10:21:13 pm »
mmm..but a loose chain can come off and wrap around rear hub or worse still double up on the front sprocket smash the cases and bend the selector shaft...ah such fond memories!  ::)
Offline brent j
« Reply #5 on: May 20, 2016, 11:22:18 pm »
What he said
