Author Topic: Honda CR250M 1973-74 Parts Wanted  (Read 3823 times)
Offline fixedit
« on: May 19, 2016, 12:55:58 am »
Looking for Complete wheels or seperate rims or hubs
To build a nice set of wheels with stainless spokes.
Also looking for Forks,Plastics and rear axle.
RH75 , 74 MX250
Offline bazza
Re: Honda CR250M 1973-74 Parts Wanted
« Reply #1 on: May 19, 2016, 03:22:49 pm »
from memory if you need a rim one of the XL 250/350 rim is same
Embrace patina
« Reply #2 on: May 19, 2016, 03:53:36 pm »
Reckon I have forks & rear axle, I definitely have XL350 forks which would be ok in a pinch. There are ordinary (very) front & rear guards as well. Located Bendigo Vic.
« Reply #3 on: May 19, 2016, 07:15:15 pm »
plastics bought readily after market if needed?
Offline fixedit
« Reply #4 on: May 21, 2016, 12:54:08 am »
Thanks Bazza,Wasn't sure if they had steel or Alloy.Hopefully Now,I'll pick some nice Honda XL rims
up without the cracks and corrosion.Saw one on Gumtree looked OK.
Thanks BigK , I'm keen on your forks, axle and plastics.
Ross asked why not go aftermarket, I found you can't get the correct
Reproduction colour in the plastic and have to paint to match.So if yours are
Repairable I'm keen.
I do have a set of fork tubes I was told they're Cr250m 73/74.They have the 5 rings turned into the top
But they seem a little long.The tubes measure 578mm long.They're out of the slider thats the shaft itself top to bottom.
And they're 35mm diameter as they're meant to be.
Thanks guys any info would help.
RH75 , 74 MX250
« Reply #5 on: May 21, 2016, 04:35:15 pm »
fair enough - I just usually find the second hand ones need repair and paint anyway.
Can we see some photos as you go?
« Reply #6 on: May 21, 2016, 06:45:18 pm »
Send me your email & I'll send photo's of what I have. CR250M plastics are painted anyway,  so it doesn't matter that the repro's need paint. The used one's I have need paint.
