Author Topic: JIS screwdrivers  (Read 30789 times)
Offline Momus
Re: JIS screwdrivers
« Reply #15 on: May 11, 2016, 06:46:44 pm »
I've been dressing Philips head  screwdrivers and impact tool bits with a cutting disc in an angle grinder for a while. These days I'm mainly worried about getting the screws outso they can be rplced with a shcs or a reduced hex flange head bolt.
If you love it, lube it.
« Reply #16 on: May 11, 2016, 07:20:42 pm »
well ive learnt something new today as ive always thought phillips head was universal no matter what country. i know theres a few different star types used in the tek screw industry though which are an 4 main points with another 4 shallow points inside which make it hard to use them without the correct driver.trust the japs to be different ;)
yep this is new to me too. it now makes sense why they do not fit snugly.
« Reply #17 on: May 11, 2016, 07:21:35 pm »
If it doesn't fit properly I don't use it ;)
reminds me of a girl i met once
« Reply #18 on: May 11, 2016, 08:19:27 pm »
im having difficulty believing you guys never knew about these things. ive checked the date and april is long gone. :o
yamaico use the same method as i do. first and every time a good wack with a drift which shocks the screw thread and tightens the head of the cross. then tap a phillips in and the screw comes out nicely no problem and you dont munt the head. actually can often fix a munted head. if it is still tight and the driver wants to slip out give it another wack with the drift as the thread is still sticking. if its tight after that even a correct JIS will want to walk out of the head.
 Most of the jap case screws are fairly soft metal and the head squashes down easily. if you check my case screws they will all be perfect crosses with slightly flattened domes.
the only screws that MUST be undone with and only a  JIS ive found are the counter sunk head screws.
Offline OverTheHill
« Reply #19 on: May 11, 2016, 08:37:56 pm »
I never knew that, bugger me, might explain a few [1000] stuffed screw heads over the years. Thought only Phillips & Posi Drive. I always use a new Koken tip in an 8mm T bar if a problem & nearly always sorts it. plus tap the screw head to reshape it first, then smack the phillips tip in. Still got a hammer driver [impact driver] on the wall but seen a lot of damage done by those by the unwary--like the little countersunk screws on the small  honda engine oil slinger end cover. [don't get me started] They do have a place though [the impact wrench].
Offline skypig
« Reply #20 on: May 11, 2016, 09:04:19 pm »
Pozidrive slots and drives are parallel*, therefore less tendency to "cam out".
Identified by the extra "corners" between the main slots.
I find a posidrive driver can sometimes get out a worn Phillips (at the risk of rounding the driver)
*Phillips head slots and drives seem to be slightly tapered. Maybe only when they are slightly worn.
« Reply #21 on: May 11, 2016, 09:49:06 pm »
Ive done all that many times with my trusty copper hammer sometimes it doesn't work and if it spins the head is munted. Especially on long case bolts that have been in situ for a while
« Reply #22 on: May 11, 2016, 10:25:27 pm »
next time i catch up with you Lozza i will give you a free demonstration.  ;D
Am yet to see a dot on a suzuki screw and none on the late model KLR either. Would make it easier to recognise but i consider all Jap screws to most likely be JIS.
« Reply #23 on: May 12, 2016, 09:05:00 am »
Offline skypig
« Reply #24 on: May 12, 2016, 04:25:19 pm »
Shovel, spade.
Arse, elbow.
Check out Pokey's avatar
« Reply #25 on: May 25, 2016, 09:22:31 pm »
Picked up a set of these and they are a sheer delight to use even have an inbuilt impact driver, not that it's really needed  ;)
CLICKY LINKY THINGY
Offline skypig
« Reply #27 on: October 08, 2016, 09:59:53 pm »
http://www.webbikeworld.com/motorcycle-tools/hozan-jis-screwdrivers-review/
That article was just what my OCD needed! :P
Bottom line, look for the DIN 5260 certification on your cross point driver and don't worry about the JIS anymore. 8)
