Author Topic: Honda TL250 flywheel wanted  (Read 6147 times)
Offline Bell moto
« on: April 19, 2016, 11:44:56 pm »
Looking for a TL250 flywheel for an XL350 project, if anyone out there has one they could spare let me know and we can work out a deal.
Cheers, Bell.
Offline James Lee
Re: Honda TL250 flywheel wanted
« Reply #1 on: April 20, 2016, 08:42:41 am »
Hi Bell,I just picked up a TL125 for parts,not sure if they are the same and also have some 185 stuff too if it fits.
Offline bazza
« Reply #2 on: April 20, 2016, 06:32:35 pm »
TL250 flywheel lighter than xl (seems strange) but true. Then turn it down heaps.
Embrace patina
Offline Bell moto
« Reply #3 on: April 21, 2016, 09:16:30 pm »
Thanks for the reply James,  will look into 125 and 185 options (unless someone on here can answer if they will work) Heard the XL250 and TL250 both fit and are lighter than stock, hence me request on this forum. If its easy enough could you weigh the 125 for me.
Cheers Bell.
Offline James Lee
« Reply #4 on: April 22, 2016, 09:14:42 am »
Im pritty sure I just found a XL250 one,I can text you a pic if you pm me your number to see if its what your after?
Offline sleepy
« Reply #5 on: April 22, 2016, 10:52:33 am »
Cheers, Bell.
I have at least 1 off each of the XL250 xl350 & TL250 flywheels here and from memory the TL and XL350 are visually the same. The XL250 is the lightest and the one most people use on the 350's. I have seen the XL250 machined down to reduce it's weight but care needs to be taken not to weaken it to much.
Offline Bell moto
« Reply #6 on: April 22, 2016, 08:24:18 pm »
Hi Sleepy, Thanks for chipping in, my research (from old posts on this forum) suggests that the XL250 weighs around 2.6kg and the TL250 around 1.85kg but I don't have either on hand to confirm those figures. If you had time to toss them on the scales we would know for sure. I'm after the lightest option but anything lighter than stock is ok.
Cheers, Bell.
Offline bazza
« Reply #7 on: April 23, 2016, 11:14:49 am »
been there bought the t shirt
TL IS LIGHTER than Xl250 !!!!!
Embrace patina
Offline Bell moto
« Reply #8 on: April 23, 2016, 01:35:08 pm »
Hey Sleepy, PM sent.
Offline Bell moto
« Reply #9 on: May 02, 2016, 08:04:31 pm »
Hey thrill seekers, still no luck turning up a TL250 flywheel, someone has to have a lead on one.
Offline Davy123
« Reply #10 on: May 03, 2016, 05:46:39 am »
xl 350 6.4lbs xl 250 5.4lbs tl 250 4.4lbs....approx..or just remove flywheel and run a total loss ignition...or even better buy an electix world electronic ignition system , it uses the standard honda rotor....first time starter hot or cold and good performance increase..
