Author Topic: 87/88 cr125/250/500 linkage bolt  (Read 2705 times)
Offline Paulos
« on: April 17, 2016, 07:52:52 pm »
I'm chasing the socket head pivot bolt that goes through the lugs on top of the swingarm through the shock linkage. Its a 12mm by 80mm-ish bolt, part number is 90128-KS6-700
Offline Krikey
Re: 87/88 cr125/250/500 linkage bolt
« Reply #1 on: April 17, 2016, 09:58:14 pm »
I think I can help  you with this Paulos. Will call you tomorrow :)
Offline Paulos
« Reply #2 on: April 27, 2016, 05:36:06 pm »
Had a couple of leads that didn't pan out so I'm still looking for this bolt.
Offline Ekka
  • Go hard or go home
« Reply #3 on: May 02, 2016, 05:33:23 pm »
Is it the one you need a allen key to remove and install
Offline Paulos
« Reply #4 on: May 02, 2016, 08:02:32 pm »
Thats the one. I may have found one over the weekend.  I'll let you know though.  Thanks for the reply.
