Author Topic: Pe250 bolts  (Read 3764 times)
Offline Wrap
Pe250 bolts
« on: April 15, 2016, 09:07:11 am »
Hello all , after pulling my PE down ,a few of the bolts are a bit shabby so was wondering is there a bolt kit you can buy or is it best to just order the bolts at Suzuki dealer      Cheers Wrap
Offline Krikey
Re: Pe250 bolts
« Reply #1 on: April 15, 2016, 01:18:54 pm »
Maxima oils sell the Bolt brand kits are great. They also sponsor VMX so we should support them whenever we can  ;)
Here's the link: http://boltmotorcyclehardware.com/
« Last Edit: April 15, 2016, 01:21:26 pm by Krikey »
Offline Oldfart
Re: Pe250 bolts
« Reply #2 on: April 15, 2016, 01:38:56 pm »
Wrap are they engine case screws ( Philip heads ) or frame bolts.
A lot depends it you want to be anal and stay genuine or go aftermarket. Aftermarket tend to have a different head size -
up from 12mm  to 13mm. There are many suppliers or aftermarket kits but have never found one specific to Pe range replicating OEM sizes exactly
If its just a rider your local Nut and Bolt supplier would be your best option.
Offline Wrap
Re: Pe250 bolts
« Reply #3 on: April 16, 2016, 04:24:01 pm »
Krikey thanks for putting the link up ,Oldfart lm going to stay original but will go aftermarket on the plastics and other parts l need , was lucky with this bike most parts there
Offline jason300
Re: Pe250 bolts
« Reply #4 on: April 16, 2016, 10:02:43 pm »
I have been down the same path and genuine is the way to go check mick hone website they have a lot of bolts in stock
Offline Oldfart
Re: Pe250 bolts
« Reply #5 on: April 17, 2016, 08:45:02 am »
http://www.alpha-sports.com/suzuki_parts.htm
Use this as a reference to see if parts are still available.   click on year .... search for model ... part
Offline Momus
Re: Pe250 bolts
« Reply #6 on: April 17, 2016, 03:42:42 pm »
Genuine bolts with the manufacturers head markings are a part of a bikes identity as well as the correct design for the job. By all means replace engine screws with shcs but if you have them get the major bolts replated.
If you love it, lube it.
Re: Pe250 bolts
« Reply #7 on: April 17, 2016, 04:22:11 pm »
Most of the bolts etc are updated now with different head styles, markings and even colours so if you really need originality zinc plating and often repairing originals is the only way to go.
