Author Topic: TT250 barrel  (Read 6945 times)
TT250 barrel
« on: April 05, 2016, 09:32:00 am »
After a decent barrel for a 1980-81 TT250.  Hoping to find one on second or third oversize (for which I have pistons).
Also after a few other bits - front sprocket cover being one.
Offline Graeme M
  • Administrator
  • Canberra, Australia
Offline oldcol
Re: TT250 barrel
« Reply #2 on: April 05, 2016, 04:39:30 pm »
I had a sr250 barrel stated 239cc on the side instead of 249cc. It would pay to check before buying that one. Col.
Re: TT250 barrel
« Reply #3 on: April 05, 2016, 05:33:17 pm »
Hmmm.  That begs the question, can you bore the SR barrel out to all the TT sizes - get it back to standard?
Offline oldcol
Re: TT250 barrel
« Reply #4 on: April 05, 2016, 06:33:03 pm »
Hole in top of crankcases is 82.3mm, assume this would be outside diameter of sleeve. I only have bottom end of sr250, don't have the barrel to measure. Hope this helps, Col.
Re: TT250 barrel
« Reply #5 on: April 06, 2016, 03:05:53 pm »
Thanks Col, never know when that info might be useful.  But good for the moment - local bike wrecker had a good XT250 barrel on second oversize, with serviceable piston and rings thrown in!  Which is terrific, as will use my higher comp TT piston in it, and have a third over piston and ring kit for if/when.
Re: TT250 barrel
« Reply #6 on: April 07, 2016, 01:30:32 pm »
are the 1984 barrels for the xt tt Dohc the same as 1991 Dohc jug
and are xt tt 250 Sohc same as the Dohc jug ?
thanx
Re: TT250 barrel
« Reply #7 on: April 07, 2016, 04:58:45 pm »
Sorry, no idea about the dohc tt's.  the sohc and dohc jugs are quite different - sohc has four compared to dohc's six barrel studs.
Re: TT250 barrel
« Reply #8 on: April 08, 2016, 09:12:18 am »
thanks
