Author Topic: YZ125d-e-f or g carb/complete engine  (Read 4909 times)
Offline Paul Harris
« on: March 22, 2016, 05:34:21 pm »
Carb + manifold/reeds or a good, complete engine wanted.
Offline Digga
Re: YZ125d-e-f or g carb/complete engine
« Reply #1 on: March 22, 2016, 08:40:51 pm »
Think I might have the old carb off my 125G somewhere if you are interested  ;)
1977 Yamaha YZ250D, 1977 Yamaha YZ400D, 1980 Yamaha YZ125G
Offline Paul Harris
« Reply #2 on: April 04, 2016, 09:56:52 am »
Thanks Digga - was it working fine? I need to check that the manifold bolts up to the DT barrel and that I can get one.
« Reply #3 on: April 14, 2016, 02:16:09 pm »
i have a motor and rubber, i can test it against a DT if you tell me what Dt.  the early stuff has smaller reads and closer spaced bolt holes.  I think the 18G is the first rubber that the wider size and bigger reeds come on.  pre that its all same as YZ125A
