Author Topic: 1979 YZ250F Carbie advice  (Read 20901 times)
Offline Ozadvntr
« on: March 14, 2016, 11:55:04 am »
Hi, just making sure I buy the correct Mikuni Carbie for a 1979 YZ250F - 38mm or 36mm?
thanks,
Mick
Re: 1979 YZ250F Carbie advice
« Reply #1 on: March 14, 2016, 12:21:36 pm »
from memory only will check the manual after but 36mm
get 2 manuals 1 for the YZ250F
and 1 for the carby SUDCO mikuni tuning manual 5th edition, GOD wrote it, its all I have to say about that!
Offline Viper666
    • Ballarat Rovers MCC
« Reply #2 on: March 16, 2016, 02:54:16 pm »
36mm
Basically any carby from yz250\400\465-E\F\G\H will do but you will need to rejet to suit.
Number #3 slide
50 pilot
Q-0 needle jet
F-16 needle (I think)
390-410 main
Obviously location heat altitude will all be determining factors.
I can double check the jetting but they are the starting point.
« Reply #3 on: March 16, 2016, 07:46:21 pm »
Bloody hell Perko how do you remember this detail after all those Beers  ;)
Offline oldyzman
  • 250 two stroke!
« Reply #4 on: March 16, 2016, 10:37:53 pm »
Ant comments on the air correction bleed jet guys?
Offline Viper666
« Reply #5 on: March 17, 2016, 11:15:03 am »
I don't.
Just guessing
Do you mean the air mixture screw? Or the needle jet mixture? I will double check that one too but I thought it was Q-0 & needle F-16 but as I said "Off memory"
« Last Edit: March 17, 2016, 02:30:18 pm by Viper666 »
Offline Viper666
« Reply #6 on: March 17, 2016, 09:13:51 pm »
Number #3 slide
50 pilot
Q-0 needle jet
6F16-4 (4 is clip position)
390-410 main
Offline oldyzman
  • 250 two stroke!
« Reply #7 on: March 17, 2016, 11:38:48 pm »
i am talking about the small jet which is at the bottom of the inlet side of the carby it bleeds air to the main and corrects mixture at high rpm. from memory it should be approx 1mm dia id, some people just take it out on bigger bores.
Offline Viper666
« Reply #8 on: March 24, 2016, 12:49:20 pm »
Still not sure what you mean but there is an air bleed jet on the 32mm. The larger ones dont have the jet just the hole where it would go.
Once you drill something out it's a bit of a pain to go back. Have to make a very small bush.
YZ125 No 4 jet
http://www.boats.net/parts/search/Yamaha/Motorcycle/1978/YZ125E/CARBURETOR%20YZ125E%20-%20F/parts.html
YZ250 no air jet
http://www.boats.net/parts/search/Yamaha/Motorcycle/1979/YZ250F/CARBURETOR/parts.html
Offline oldyzman
  • 250 two stroke!
« Reply #9 on: April 04, 2016, 04:21:30 pm »
yep, thats the one i meant...
Offline Ozadvntr
« Reply #10 on: April 16, 2016, 08:39:05 pm »
I just checked an old test and everything I read suggests a 38mm Carbie.
I also understand that 36mm will give an increase in torque. Is this correct?
Offline oldyzman
  • 250 two stroke!
« Reply #11 on: April 17, 2016, 04:21:39 pm »
 Definitely 38mm according to my info and samples.
Offline motomaniac
« Reply #12 on: April 17, 2016, 07:15:40 pm »
36 mm carby on the 77 yz 250 d , 38 mm on the E and F , 400 had 38 mm from the D model on
Offline Ozadvntr
« Reply #13 on: April 18, 2016, 10:09:13 am »
thanks, Just ordered a new 38mm. Just over $200 delivered to me with all the correct jetting in a separate kit.
thanks for the advice.
Offline Viper666
« Reply #14 on: May 31, 2016, 10:05:48 am »
38mm
Stand corrected
