Author Topic: RM250c and 1982 DR250 FORK OIL QUANTITY - Help please  (Read 5493 times)
Offline bazza
« on: March 09, 2016, 04:26:25 pm »
RM250C and 1982 DR250 Forl oil quantity please
Thanks ;) ;)
Embrace patina
Re: RM250c and 1982 DR250 FORK OIL QUANTITY - Help please
« Reply #1 on: March 09, 2016, 08:10:07 pm »
250C amount will depend on what air spring curve you want. The owners manual has the std amount will be similar to 125 B where they list different curves depending on oil level and pressure.
you can find it here
https://onedrive.live.com/?id=407D7EF0965D3991!3198&cid=407D7EF0965D3991
Is the DR a DR250SZ (35mm forks)
or DR250Z (36mm forks)
Offline bazza
« Reply #2 on: March 09, 2016, 08:22:40 pm »
Thank you
Embrace patina
« Reply #3 on: March 09, 2016, 08:57:54 pm »
I assume you are meaning 250C and not 250C2 forks as well but i got both specs here.
I just checked my Cylmer manual (M371) and standard spec is 273ml with 268mm low level and 298ml high level for 250c
and 250c2 is 292ml std, 286ml low and 304ml high.
level range 250c - std 139mm - 114-144mm range
level range 250c2 - std 164mm - 144-174mm range
please note standard oil level on 250c2 with frame number 30643-35674 is 169mm
I don't think i have a DR manual though??
This thread probably would have been more suited to 'Suzuki' or 'Tech info' rather than 'general' so other people can find it while searching :-\
« Last Edit: March 09, 2016, 09:04:06 pm by LWC82PE »
