Author Topic: Rims from India  (Read 18608 times)
Offline Gippslander
Rims from India
« on: March 05, 2016, 02:20:47 pm »
Has anyone tried these?
http://www.ebay.com.au/itm/262014219419?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
to be used on a 74 KTM - the 40 hole rear makes it a bit hard to buy rims, last one I got from Titman was a Morad -- top class rim but is was $400 approx. and that was 5 years ago.....
Offline pecrazy
Re: Rims from India
« Reply #1 on: March 05, 2016, 03:14:11 pm »
If their anything like the rims I bought from Thailand run a mile.
Offline Tomas
Re: Rims from India
« Reply #2 on: March 05, 2016, 04:17:57 pm »
Why not Buchanan in US. I know the Ozi buck is worthless at the moment but they will drill nondimpled Takasago or Sun rim for you. What I dont like about rim from JTR is that they redrill already drilled rim to suit your hub. You have to buy spokes and nipples too cause the holes are too big for stock nipples. If you want to wreck your bike and maybe end up in wheel chair because of a cheap rim buy a cheap rim. Good luck
Offline roost250
Re: Rims from India
« Reply #3 on: March 05, 2016, 07:33:48 pm »
Would be good to hear if there are some good value rims (known brands) out there though.  A pair of wheels around  $ 800 is a lot to spend when that represents about a third of the bike's worth!
Offline Gippslander
Re: Rims from India
« Reply #4 on: March 05, 2016, 08:29:52 pm »
Yep can go Buchanan, but was just lookin for an alternative at a more reasonable price
Have sent an enquiry to Buchanan for a quote -- will see but it may be too much $
Offline tymes
Re: Rims from India
« Reply #5 on: March 06, 2016, 01:22:21 am »
Every time someone mentions a cheep rim alternative its like "you cant use them they will explode and the fallout will kill everyone in a hundred kilometre radius"
Ive seen standard rims that were rotted till they were paper thin and cracked bent and buckled, missing spokes and those that were still on there so loose that the rim flaps side to side like a flag in the wind. The worse thing that happened was a flat tyre
Will the bike be jumping 50 feet high or maybe breaking the world land speed record.
Every chinese pod filtered pit bike are fitted with them.
Offline ian
Re: Rims from India
« Reply #6 on: March 06, 2016, 08:21:25 am »
give ash.s spoked wheelz a ring top service and good prices .hes in Brisbane
Offline djr
Re: Rims from India
« Reply #7 on: March 06, 2016, 09:44:08 am »
If you have  some doubts but want to try these Indian rims to save a bit of money , maybe try one on a rear wheel first, and see how it works .
The reason being if a rear wheel breaks, the crash you will have won't be anything like as bad as if a front wheel collapsed
A bit like using a really old Magnesium Hub, I would rather take a chance with one on the rear wheel but not the front
Offline Blackjack
Re: Rims from India
« Reply #8 on: March 06, 2016, 12:09:09 pm »
Not going to suit OP and probably limited vmx applications but Torpedo7 does 32h and 36h rims in various sizes including spokes and nipples for $126.00
Re: Rims from India
« Reply #9 on: March 06, 2016, 12:35:20 pm »
The motorcycles they make pass our adrs using same rims
Offline fred99999au
Re: Rims from India
« Reply #10 on: March 07, 2016, 09:20:14 pm »
Problem with the Torp7 rims blackjack is that they are drilled for disc hubs and the nipple holes are enormous. I say that speaking from lacing up a couple of IT hubs.
Offline rocketfrog
Re: Rims from India
« Reply #11 on: March 07, 2016, 10:12:24 pm »
Fred, did you get the IT wheels built using top rims? I have seen oversized nipples available around the traps, in the UK IIRC.
Offline fred99999au
Re: Rims from India
« Reply #12 on: March 08, 2016, 07:39:48 am »
Nah, I laced them up using Kedo spokes from "The Vintage Spoke" which are stainless but supposed to be original sized and I used the Torpedo7 rims.
More of an experiment than anything as I am struggling to justify the $500 per wheel to get them done professionally on a $700 bike. Haven't revisited the experiment recently, I just walk past the shiney front wheel and think. "need to get back to that"
Re: Rims from India
« Reply #13 on: March 08, 2016, 11:09:10 am »
I've got Torpedo7 rims on my CZ, rear had to redrilled to suit but probably would have anyway because I'm using buchannan spokes which have larger nipples from what I can tell. Front was pretty close even with the size difference of the 2 sides of the hub
Offline rocketfrog
Re: Rims from India
« Reply #14 on: March 08, 2016, 01:55:51 pm »
Those KEDO spokes are available in Aussie from Kedo direct if you dont want to pay international shipping from vintage spoke USA.
But while I am at it I must give Bruce from Fastline spokes (Broadford, Vic) a plug.
Got some spokes from him recently made from samples, great price for butted stainless spokes like OEM, delivered interstate no probs and easy to communicate with via phone.
First class service and products.
I have also bought some cheapy rims from Ebay via Melbourne via China at about $80 Aussie a piece. I consider these to be fit for small capacity bikes that will not leave the ground more than a few inches with a lightweight rider or just for show. I think they are veeerryy cheep, but fine for the kids RM100 bush basher.
