Author Topic: Flywheel puller for 1979 RM400N  (Read 2885 times)
Offline Twinshock
« on: February 29, 2016, 12:49:42 pm »
Can anyone tell me what size I need to buy or suggest somewhere I can buy one to suit an RM400N?
There's lots on eBay but they all look different.
I'm keen to ensure I buy the right one.
Thanks in advance.
Always on the look out for a new project bike
Offline Oldfart
Re: Flywheel puller for 1979 RM400N
« Reply #1 on: February 29, 2016, 05:17:52 pm »
Buy 3 allen head bolts 50mm long @  M5 x0.8 pitch  spacing between drill hole in flat  plate 21mm
Buy a bolt 65mm long with at least 45mm of thread  plus a nut.
Tack weld the nut or thread the plate to take your bolt centre of 3  three drilled holes.
20 minutes is all it takes to make one :-)
hint ... you can use your mag as a template for measurements.
Offline Twinshock
« Reply #2 on: March 02, 2016, 09:42:03 pm »
Thanks Oldfart,
Sounds like you've done this a time or two before.
really appreciate the advice
« Reply #3 on: March 03, 2016, 10:08:57 pm »
Just remember to put a bit of aluminium/bronze/brass between the end of the centre bolt and the end of the crank
