Author Topic: YZ 125 F 1979 REAR WHEEL  (Read 5495 times)
Offline Tim37
  • Its an investment ...had to buy it !
« on: February 20, 2016, 06:08:35 pm »
Hi , my apprentice Tony bought a yz 125 f and its missing the rear wheel and axle brake as well as chain adjusters ..anyone have anything to sell ...also what other model wheels will suit .....thanks Tim
Re: YZ 125 F 1979 REAR WHEEL
« Reply #1 on: February 20, 2016, 08:06:17 pm »
According to partzilla wheel is 1 year only, axle adjusters are used from 78-81, axle from 78-80
Possible that other wheels fit but require the brake assembly as well, shoes are quite common but brake plate is unique to the 125F
Offline Tim37
« Reply #2 on: February 23, 2016, 09:17:30 am »
Thanks Tony that helps lots !
« Reply #3 on: February 23, 2016, 11:04:54 am »
You can use monoshock DT125/175 wheels, IT125, IT175D/E/F or YZ125D/E wheels.
Don't know why there's a different part number.
« Reply #4 on: February 23, 2016, 11:34:55 am »
dt's steel rims
« Reply #5 on: February 23, 2016, 02:15:47 pm »
Not all, but generally yes.
« Reply #6 on: February 24, 2016, 12:06:27 am »
pm sent re backing plate
Offline motomaniac
« Reply #7 on: February 24, 2016, 07:08:25 pm »
I should have all of that off an E , as far as I know 100% interchangeable.
Offline FDR
« Reply #8 on: February 24, 2016, 08:24:53 pm »
F model has floating rear brake, E model has backing plate anchored to swingarm.
Presume hub is the same.
Offline motomaniac
« Reply #9 on: February 24, 2016, 08:37:38 pm »
thanks FDR , Forgot about that.
