Author Topic: Winners and Losers...  (Read 15751 times)
Re: Winners and Losers...
« Reply #15 on: February 19, 2016, 09:40:11 am »
Where do you buy the black carb primer button  these days ...  had no luck at mower shop??
I bought my last one from the local mower shop. They come complete with the white nylon float hatch door, new needle and o ring $14. There is also 80 of them on ebay.
Offline Matador107
« Reply #16 on: February 19, 2016, 10:48:41 am »
Victor Richardson lived in Concord NSW not Melbourne Vic.A mate of his who worked at the nearby Mortlake gas works in Sydney had a lot to do with it as a foreign order ( remember them ) !!!
A friend of mine has a mower shop and ordered a Victa  two stroke for a customer last July 2015, he received it a few weeks ago and has another 6 customers waiting.
I saw a bike at Moorebank scrambles back in the day fitted with a Victa motor!!!
Bultaco Metralla, Matador MK 5, Montadero mk2, El Bandido model 18,plus lots of bits and two Honda XR's 250,350.
« Reply #17 on: February 19, 2016, 11:08:05 am »
My first motorbike experience was a bike we built as mates when we were just turning 10. Lived near the Newcastle tip. Treasure land. Victa 18  came from there. A couple of inches of Rubber air hose forced over the end of the crankshaft, with washer and nut put back on to hold it there which ran directly onto the rear tyre of the 28" inch Speedwell. Bolted on via two 1/4" flat bars bent to 90deg angles. One engine bracket, bolted/clamped to the area that a side stand normally would be just in front of rear wheel but behind pedals crank. The other bracket bolted through lower frame spar that runs to rear. Pedal crank removed and a long industrial bolt with pipe sleeves fitted for foot rests pegs. Victa 18 fuel tank tied under top bar. Continuous direct drive. Throttle lever on handle bar. The smaller one of us would sit in the turned up racing bars. The skipper on the seat with thumb on throttle. A third would push until fired!! Then run along beside and jump up side saddle on to the top bar. Obviously we only rode it on the road. It was fast too. We loved it. Coppers didn't, hence the forced  closure of Newcastle Motorcycle inc.
It was shortly after that we discovered stepthru's, had a thing called suspension. So we disappeared into the scrub in stead.
« Last Edit: February 19, 2016, 12:01:57 pm by Mick D »
Offline Matador107
« Reply #18 on: February 19, 2016, 01:06:30 pm »
Plus no shoes, Dunlop volleys or thongs!!!
Obviously you blokes went on to a career in innovative engineering.
Cheers.
Martin
Offline the stig
« Reply #19 on: February 19, 2016, 09:54:05 pm »
     I still use my Victa slasher the Self propeld model .
     I gave my Daughter my victa mower 3 years ago now she wont part with it
     I also had a Victa out board a few years ago they built a Jet leg and put the 125 motor on it it was
    great for trolling for Cod in the Murray River no Engine noise in the water...wish i still had it..
   The Stig
