Author Topic: PE250 X/T speedo  (Read 3562 times)
maxvmx
PE250 X/T speedo
« on: January 31, 2016, 06:00:37 pm »
Not sure if I should post this here or in funniest jokes but I'm after a OEM speedometer for my PE250X that works well, fall back would be a OEM trip meter. I'll leave the NOS OEM rear guard and tail light out for another occasion.
Thanks.
Re: PE250 X/T speedo
« Reply #1 on: January 31, 2016, 06:29:57 pm »
The tripmeter (little square block type as fitted on US models) you can still buy brand new in KM's. The original 78-84 tripmeter upgrades to the RMX250 tripmeter and is the same looking thing. I got one and the only difference from memory was that the RMX one had a more rubbery reset knob rather than hard plastic. Also i think its the same as the modern DRZ400? tripmeter in some markets too. I figured this all out ages by researching part numbers but i lost all the exact specific info from my computer. If you are good with siuzuki numbers and also have Zedder you might be able to work it out too, otherwise start looking at 90's model pre ADR??? RMX250 as they have the KM tripmeter.
If you still want the round speedometer then the 76 TS250 is the closest alternative. Only difference is black face rather than brown. There are guys out there that can reproduce the faces though because i bought repro faces for a CB750 from Holland and they are very good, properly printed (not stick on decal) with ND logos and look like they are originals. If there was enough of a demand i guess he could do them for Suzuki speedos too.
Here we go
original mile tripmeter  is
Part # = 34721-41411
Part Description = _
Model Count = 7
PE175C 1978 172 PE175 DUAL PURPOSE
PE175N 1979 172 PE175 DUAL PURPOSE
PE175T 1980 172 PE175 DUAL PURPOSE
PE250C 1978 246 PE250 DUAL PURPOSE
PE250N 1979 246 PE250 DUAL PURPOSE
PE250T 1980 246 PE250 DUAL PURPOSE
PE400T 1980 397 PE400 DUAL PURPOSE
then that goes to this in Miles so a lot of these models will have KM equivalents in other markets which is part number 34721-40600
Part # = 34721-40610
Part Description = TRIP METER
Model Count = 45
DR100D 1983 100 DR100 DUAL PURPOSE
DR100E 1984 100 DR100 DUAL PURPOSE
DR100F 1985 100 DR100 DUAL PURPOSE
DR100G 1986 100 DR100 DUAL PURPOSE
DR100H 1987 100 DR100 DUAL PURPOSE
DR100J 1988 100 DR100 DUAL PURPOSE
DR100K 1989 100 DR100 DUAL PURPOSE
DR100L 1990 100 DR100 DUAL PURPOSE
DR125G 1986 125 DR125 DUAL PURPOSE
DR125H 1987 125 DR125 DUAL PURPOSE
DR125J 1988 125 DR125 DUAL PURPOSE
DR125Z 1982 125 DR125 DUAL PURPOSE
DR200G 1986 200 DR200 DUAL PURPOSE
DR200H 1987 200 DR200 DUAL PURPOSE
DR200J 1988 200 DR200 DUAL PURPOSE
DR250D 1983 250 DR250 DUAL PURPOSE
DR250L 1990 250 DR250 DUAL PURPOSE
DR250M 1991 250 DR250 DUAL PURPOSE
DR250Z 1982 250 DR250 DUAL PURPOSE
DR350L 1990 350 DR350 DUAL PURPOSE
DR350M 1991 350 DR350 DUAL PURPOSE
DR500D 1983 500 DR500 DUAL PURPOSE
DR500X 1981 500 DR500 DUAL PURPOSE
DR500Z 1982 500 DR500 DUAL PURPOSE
PE175D 1983 172 PE175 DUAL PURPOSE
PE175E 1984 172 PE175 DUAL PURPOSE
PE175X 1981 172 PE175 DUAL PURPOSE
PE175Z 1982 172 PE175 DUAL PURPOSE
PE250X 1981 246 PE250 DUAL PURPOSE
PE400X 1981 397 PE400 DUAL PURPOSE
RMX250K 1989 249 RMX250 OFF ROAD
RMX250L 1990 249 RMX250 OFF ROAD
RS175X 1981 175 RS175 DUAL SPORT
RS175Z 1982 175 RS175 DUAL SPORT
RS250X 1981 250 RS250 DUAL SPORT
then it goes to
Part # = 34721-05D20
Model Count = 65
DR-Z400EY 2000 400 DR-Z400E DUAL PURPOSE
DR-Z400Y 2000 400 DR-Z400 DUAL PURPOSE
DR250N 1992 250 DR250 DUAL PURPOSE
DR250P 1993 250 DR250 DUAL PURPOSE
DR350N 1992 350 DR350 DUAL PURPOSE
DR350P 1993 350 DR350 DUAL PURPOSE
DR350R 1994 350 DR350 DUAL PURPOSE
DR350S 1995 350 DR350 DUAL PURPOSE
DR350T 1996 350 DR350 DUAL PURPOSE
DR350V 1997 350 DR350 DUAL PURPOSE
DR350W 1998 350 DR350 DUAL PURPOSE
DR350X 1999 350 DR350 DUAL PURPOSE
RMX250M 1991 249 RMX250 OFF ROAD
RMX250N 1992 249 RMX250 OFF ROAD
RMX250P 1993 249 RMX250 OFF ROAD
RMX250R 1994 249 RMX250 OFF ROAD
RMX250S 1995 249 RMX250 OFF ROAD
RMX250T 1996 249 RMX250 OFF ROAD
RMX250V 1997 249 RMX250 OFF ROAD
RMX250W 1998 249 RMX250 OFF ROAD
which is the current version in miles and the current KM version is
34721-05D30
Now all the info is up here and easy to find :)
« Last Edit: January 31, 2016, 06:51:50 pm by LWC82PE »
