Author Topic: wanted 31mm triple clamps  (Read 4758 times)
« on: January 27, 2016, 07:01:48 am »
looking for 31mm triple clamps that the forks can slide through without hitting handle bars.only need top and bottom for my project
thanks
jim
Re: wanted 31mm triple clamps
« Reply #1 on: January 27, 2016, 09:27:49 pm »
Yamaha it 125 31mm clamps
« Last Edit: January 29, 2016, 10:40:26 pm by jimg1au »
« Reply #2 on: January 29, 2016, 10:40:55 pm »
Bump
« Reply #3 on: January 29, 2016, 11:02:40 pm »
Here are some 31mm
Do you know what width you need or what stem length or offset you need etc? What about the forks, leading axle or non leading axle will determine what offset your should need. I am sure there would be plenty on ebay.
Yamaha IT-125 G (80) are 32mm according the my source of the below info
31 Honda CR-80R (82)
31 Honda CR-80R (83)
31 Honda SL-100 K (69-70)
31 Honda XL-100 (74-78)
31 Honda XL-100S (80 From 5103464)
31 Honda CB-125TT (90)
31 Honda CR-125M/M1 “Elsinore” (74-75)
31 Honda MT-125K (74-76)
31 Honda SL-125 “Motosport 125? (72-73)
31 Honda TL-125K “Trials 125? (73-75)
31 Honda XL-125K/K1 (74-78)
31 Honda XL-125S (80 From 5005876- 82, 84)
31 Honda XL-125S (85)
31 Honda CB-175K3-K7 (69-73)
31 Honda MR-175 “Elsinore” (76-77)
31 Honda SL-175K1 (71)
31 Honda CM-185T “Twinstar” (78-79 To 2111990)
31 Honda CM-185T “Twinstar” (79 From 2111991)
31 Honda XL-185S (79-80 To 5006890)
31 Honda XL-185S (80 From 5006891 – 83)
31 Honda CB-200T (75-76)
31 Honda CM-200T “Twinstar” (80 To 2012204)
31 Honda CM-200T “Twinstar” (80-82)
31 Honda TR-200 “Fatcat” (86-87)
31 Honda XR-200 (80-84)
31 Honda CB-250 “Nighthawk” (91-04)
31 Honda CM-250C “Custom” (82-83)
31 Kawasaki KX-80 C2 (82)
31 Kawasaki KX-125/ A1-A3 (74-77)
31 Kawasaki KZ-200A1/A2 (78-79)
31 Kawasaki KZ-250D1/D2 (80-81)
31 Kawasaki KZ-250L1 “CSR” (82)
31 Kawasaki EX-305B1 “GP” (83)
31 Suzuki SP-100 D (83)
31 Yamaha DT-125 E (78)
31 Yamaha DT-175 E (78)
« Last Edit: January 29, 2016, 11:05:37 pm by LWC82PE »
« Reply #4 on: January 29, 2016, 11:10:14 pm »
Don't need a stem for leading axle forks but need to be able to slide forks through top clamp past the handle bars
Offline Momus
« Reply #5 on: January 30, 2016, 01:19:46 pm »
If you cannot find what you need in 31 mm but you have larger you could machine up some split bushes to sort it.
If you love it, lube it.
« Reply #6 on: January 30, 2016, 05:23:54 pm »
Yes I know that as I had 27mm forks in the 31mm triples I got some real good 31mm leading axle forks and when I undid the top triple one side was broken
« Reply #7 on: January 30, 2016, 06:44:06 pm »
1) You can buy some 30mm and ream them.
2) You can buy some 32mm and shim them with 0.5 shim metal from every bearing selling service.
3) I have some XR 200 83 model triples I dont need.
« Reply #8 on: January 31, 2016, 11:18:42 am »
Early-mid 80's DR/SP/DF 125 are 32mm leading axle clamps and have laid back bar mounts which will allow sliding the forks up. But unless the offset and width of the your current bottom clamp matches, it will mean using the matching 32mm suzuki lower clamp aswell. Adapating this to another bike would be tricky because this suzuki lower clamp is all steel and has welded in stem so if you need to change stem then its gonna be tricky. Either you need to find a top clamp that matches your lower or you need to use a lower and upper that will match your frame with no mods to stem required or if stem mods are required then make sure the lower triple is an alloy one with press in/pinch up fitted stem that you can easily remove, put in lathe and shorten or fit a new one. You have not said what bike you need the clamp for. All Balls site has a bearing chart that shows you what size bearings each bike has and if its easily possible to swap triple clamps from one make onto another.
« Last Edit: January 31, 2016, 11:21:55 am by LWC82PE »
HeavenVMX
« Reply #9 on: January 31, 2016, 11:41:33 am »
Jim would a set of offset bar clamps allow you to do what you want? There are many suppliers on ebay. I have used them on a TY250 to get rid of the TY rearward bar offset and bring the bars forward. You can use them the opposite way to move the bars rearward. Give me a ring if they may help as I may even have a set you can have if they are any good to you.
They look like this
http://www.alibaba.com/product-detail/Machinery-spare-parts-Motorcycle-parts-Aluminium_60228136406.html?spm=a2700.7724857.29.91.oV7PJ6
That way you make your search for triple clamps much simpler
« Last Edit: January 31, 2016, 12:30:35 pm by HeavenVMX »
