Author Topic: Yamaha DT 250 C Rear Sprocket  (Read 9958 times)
Offline llewdaert
« on: January 25, 2016, 11:25:14 pm »
I am having trouble locating a new replacement rear sprocket for a  Yamaha  DT 250 C . The local seller can only source an 62mm ID sprocket-whereas the one I have removed has a 60mm ID .
The PCD for the bolt holes is Ok -but the ID is wrong... This problem is causing me anxiety, can anyone shed light onto the problem please?
James
Offline dont
Re: Yamaha DT 250 C Rear Sprocket
« Reply #1 on: January 26, 2016, 05:46:05 pm »
My DT2 is 60 I'm pretty sure but didn't take the wheel off - def not 62.
Of course its a few years older
Offline llewdaert
« Reply #2 on: January 26, 2016, 08:21:12 pm »
Offline llewdaert
« Reply #3 on: February 06, 2016, 06:09:02 pm »
Ok Where do I buy a DT 2 sprocket please. I have been looking, and USA looks like the only place available??
James
« Reply #4 on: February 07, 2016, 10:07:40 am »
did a search through my sources and I agree - lots available but all stateside and varying in price.
Offline SUZUKI311
« Reply #5 on: February 07, 2016, 11:53:36 am »
Try Les Penna motorcycles in Bendigo, long time Yamaha dealers that carried a lot of genuine sprockets from that era, 0354435375. I just picked up a genuine nos yz80 sprocket from them, paid a bit for it, but they had it and it was the correct item.
Offline llewdaert
« Reply #6 on: February 07, 2016, 10:21:15 pm »
I will ring tomorrow-Thanks for your help.
James
Offline llewdaert
« Reply #7 on: February 07, 2016, 10:22:44 pm »
Thankyou -
I appreciate your effort -
It is good to have confirmation that they are hard to find here....
James
« Reply #8 on: February 07, 2016, 10:35:51 pm »
Try a bike shop that deals with Link International, Cykel Parts Suppy or Ficeda accessories. Link list tooth count of 46T for 3Y1 prefix. Generally it will be JT brand but if its real old stock it might come as a Link or Unico brand, made in Japan. Shops these days may not have what you want in stock for an older model but their catalogues will list it and they can order it in from the main warehouse for you. Might only be a few days wait.
« Last Edit: February 07, 2016, 10:37:57 pm by LWC82PE »
Offline micko
« Reply #9 on: February 08, 2016, 02:31:03 pm »
I just went through the whole JT Sprocket spec book (Link) there is nothing in a 520 pitch with a 60mm id. The 3Y1 they list for the DT250A-C is 62mm id and has a genuine Yamaha reference #30X. Maybe you could use a spacer in the centre,  the 3Y1 come in 40,43,45,46,47,49 and 51 teeth.
hope this helps.
Offline llewdaert
« Reply #10 on: February 09, 2016, 07:43:56 am »
Thanks gents.
The sprocket is harder to source than I would have expected.
I am considering making an interference fit sleeve [od  62mm] for the cush drive.
I think that will fix the problem-the hard way....
james
Offline jimson
  • Sanctuary point N.S.W
« Reply #11 on: February 09, 2016, 10:00:55 pm »
Try this mob. wemoto.com.au motorcycle parts ph 0244217048 hope they can help you. Jimson
« Last Edit: February 09, 2016, 10:02:37 pm by jimson »
Offline matcho mick
    • Moto Tumbi
« Reply #12 on: February 10, 2016, 10:05:20 pm »
J & J in railway st ,Weston,(you know,not far from newie  ;)),guys there do whatever you want,in steel only,(not pretty),did my 415 X 37t/39t rears with centre machined to my specs,can't remember what they're called think it could be J & J chains??,lot of mining stuff, pallets of forking big sprockets out front, hard to spot too,their signage is overgrown with trees,sorta 100yds in,opposite rail line,going the backway to Kurrie speedway,turn left before rail stop sign into railway st, :P
