Author Topic: bike bench  (Read 24759 times)
Offline mic
bike bench
« on: January 17, 2016, 08:05:53 pm »
got bored to today so nocked up a bench for the 125M1 iam workin on, roll in & roll out....
-toe -
74 XR75 - 75 CR125M1 - 84 XR500 x 2 - 79 CR250 x 2
Offline crash n bern
Re: bike bench
« Reply #1 on: January 17, 2016, 11:45:39 pm »
Love the door and the flat tyres. That's gold.
Offline mic
Re: bike bench
« Reply #2 on: January 18, 2016, 08:22:56 am »
i have done so much with so little for so long i can do almost anything with nothing :)
nice spotting... got a couple of tubes coming....
-toe -
Re: bike bench
« Reply #3 on: January 20, 2016, 04:10:12 pm »
The tubes will cost you more than the whole bike stand.
I built a sandblasting cabinet once, took me about a year to scavenge every single part from the tip. Wanted to see if I would use it enough to warrant buying a flash one. My whole place kinda looks like your bike stand, so I relate.
« Last Edit: January 20, 2016, 04:11:47 pm by crash n bern »
Offline mic
Re: bike bench
« Reply #4 on: January 20, 2016, 04:16:22 pm »
yer, $21 each at masters, found em on ebay 2 for $21 :)
my next project just happens to be a sand blaster, any chance of flicking some ideas over this way m8?
-toe -
Re: bike bench
« Reply #5 on: January 21, 2016, 11:49:07 am »
Ever tried changing a tube on one of those wheel barrow tyres.... >:( See if you can get some wheelie bin solid wheels to fit.
Offline dirttracker
Re: bike bench
« Reply #6 on: January 21, 2016, 05:59:04 pm »
go to supercheap auto I think a trolley with those wheels will only cost about $20
Re: bike bench
« Reply #7 on: January 21, 2016, 06:53:13 pm »
nothing wrong with making projects from using cheap dump/dump shop bits and pieces crash and burn, me i hate cutting into a full length of inch square tube if i can find a piece in my stash that i got off the dump ;)a good place to shop when all the council workers are at lunch ;D ;D
Offline mic
Re: bike bench
« Reply #8 on: January 21, 2016, 07:59:29 pm »
same
-toe -
Offline MaxPower
Re: bike bench
« Reply #9 on: January 25, 2016, 11:20:23 pm »
Make the tires solid
http://youtu.be/car8Wck586U
Re: bike bench
« Reply #10 on: January 26, 2016, 01:38:22 pm »
[/quote]
Yeah, buy a good one.
I used an old kitchen sink, built a ply box around it used a perspex lid and bought a cheap blasting gun. Cut holes in for may hands and used car inner tube with X's cut into them over the holes. But you could staple some long industrial rubber gloves in there. I let the sand run out the bottom of the sink into a bucket that I had the sandblaster hose in.  It worked okay for bit's and pieces, then I upgraded to a bench top unit. Then one birthday I bought myself a freestanding one with built in vacuum.
I'm bad with timber. I've scavenged a fair bit of hardwood over the years and like the steel, I will spend all day trying to find an off cut somewhere because I don't want to cut a piece off a full length. The irony is I have all this timber I've hoarded that will probably never get used. It's always "Oh, I'll save that for something better." I've even gone and bought cheaper timber so not to use the good stuff. You can only laugh at yourself.
Offline mic
Re: bike bench
« Reply #11 on: January 26, 2016, 02:16:18 pm »
sounds good buying one :)
i am a bit like you when comes to steel also...
bench is working good but will need to piss the door off and use a bit of ply maybe.
were did u get the s/blaster?
wht u rekon about this one?
http://www.supercheapauto.com.au/online-store/products/Portable-Air-Sand-Blast-Gun.aspx?pid=377686#Recommendations
-toe -
Re: bike bench
« Reply #12 on: January 26, 2016, 06:41:39 pm »
I started with one of these. https://www.tradetools.com/product-range/machinery-and-workshop/sandblasters/renegade-industrial-portable-sand-blasting-cabinet-risbc90
But got sick of not being able to see and having to stop every five minutes to push the sand back into the bottom so it could pick up.
I now have one of these.https://www.tradetools.com/product-range/machinery-and-workshop/sandblasters/renegade-industrial-sand-blast-cabiniet-floor-standing
Offline mic
Re: bike bench
« Reply #13 on: January 27, 2016, 08:48:50 am »
i will be blasting the frame also so probably cannot use that box style..
-toe -
Offline Andrew L
Re: bike bench
« Reply #14 on: January 27, 2016, 09:39:05 am »
A good compressor that can keep up is essential as well.
