Author Topic: AT1/2 or AG175 exhaust heat shield and forks.  (Read 1598 times)
« on: August 04, 2008, 05:55:22 pm »
As the title says....
Exhaust heat shield:
Toaster rack style, to suit a leg-burner pipe. Should have space for an oval badge in the middle. Held onto the pipe with four 6mm screws.
Doesn't have to be perfect, but I don't need another rough one....
AG100 item does not fit (I can swap a good Ag100 heat shield if it helps... >:().
LT1 and CT1 items might fit - I can supply the dimensions if needed.
Forks:
Alloy lower legs, pissy diameter fork tubes, also fitted to CT1, and twin-shock DT175/125.
04000 23847 if you can help.
Offline DG 26
  • 250H 125D it490 looking for pre75bike
Re: AT1/2 or AG175 exhaust heat shield and forks.
« Reply #1 on: August 09, 2008, 09:40:09 am »
Giday nathan
may have an exhuast heat shield? see you at RD6 at canberra
don
