Marketplace
Wanted
IT 175 ignition parts
Topic: IT 175 ignition parts (Read 5037 times)
TC91
C-Grade
January 12, 2016, 01:57:33 pm »
Hi all, I am after ignition parts to suit 77 - 79 It175, prefix numbers 1w2-85500-20-00 or 2w6-85500-20-00.
TT5 Matt
Re: IT 175 ignition parts
January 12, 2016, 04:23:06 pm »
what parts do you need? or do you need the whole system including the rotor?
TC91
C-Grade
January 13, 2016, 10:57:59 am »
The whole lot excluding the ignition coil
TT5 Matt
January 13, 2016, 04:35:57 pm »
ok so you need a stator/rotor/cdi and wiring loom? theres a it175 D at the wreckers and im pritty sure all the sparks are still on it
TC91
C-Grade
Reply #4 on:
January 13, 2016, 06:59:13 pm »
sounds good, where do I go from here
fen880
Novice
Reply #5 on:
January 16, 2016, 08:50:23 am »
I have a rotor and stator of a 81 IT 175 that might work some one here will know
TT5 Matt
Reply #6 on:
January 16, 2016, 07:55:45 pm »
id say the rotor would be wrong as the maggie is on the oposite side of the motor and would be spinning clockwise instead of anticlockwise but im sure others would know more on yams then i do
fred99999au
A-Grade
Reply #7 on:
January 16, 2016, 09:39:28 pm »
Start here and figure it out.
http://www.partzilla.com/parts/search/Yamaha/Motorcycle/1979/IT175F/C+-+D+-+I+-+MAGNETO/parts.html
click on the parts and they will tell you what else it fitted in the US at least.
for example, the rotor is listed as:
This Yamaha 1W2-85550-20-00 ROTOR ASSEMBLY is used on these models and components:
1977 IT175D C - D - I - MAGNETO
1978 IT175E C - D - I - MAGNETO
1979 IT175F C - D - I - MAGNETO
1980 IT125G C - D - I - MAGNETO
1981 IT125H C - D - I - MAGNETO
TT5 Matt
Reply #8 on:
January 17, 2016, 12:21:48 am »
true a it125g/h that were using the old motor design are the same rotor but fen880 was talking about a 81 IT175H rotor and its part prefix starts with 3r6 and not 1w2 and is on the oposite side of the motor to the old 1w2/2w6 motors
CCM73
Novice
Reply #9 on:
January 17, 2016, 10:28:36 pm »
Think I;ve got a complete ignition at work ...... will check tomorrow . Steve
It's always the ignition
Marketplace
Wanted
