Author Topic: 74 mx 250a spark issues  (Read 5456 times)
Offline fen880
« on: January 08, 2016, 10:03:11 pm »
Hi got a mx 250 with spark issues ie sometimes it sparks sometimes it doesent  . I am starting to think the cdi unit is had it ,but in my experience cdi boxes either work or they dont ?  Anyone got any ideas on this
                         Cheers Ben
Re: 74 mx 250a spark issues
« Reply #1 on: January 08, 2016, 10:32:00 pm »
what temp is the motor when the spark dies
Offline fen880
« Reply #2 on: January 08, 2016, 10:36:55 pm »
Usually when its cold
HeavenVMX
« Reply #3 on: January 08, 2016, 10:55:28 pm »
Bad earth? Have you recently painted the frame or engine and forgot to remove paint from engine mounts or coil/CDI mounts?
Run a separate wire from magneto backing plate to coil base and CDI box mount point to ensure a good earth
« Last Edit: January 08, 2016, 10:57:49 pm by HeavenVMX »
Offline fen880
« Reply #4 on: January 08, 2016, 11:55:32 pm »
Buke hasnt been painted or anything just hasnt been run for at least 10 years i gave it all a cleanup but will give it another going over . Am i right in thinking that a cdi wont work intermittently it will either work or it wont ?
          Ben
« Reply #5 on: January 09, 2016, 12:11:02 am »
electronics do funny things sometimes,if it was me id send the whole ignition system off to beta bikes or someone like that where they can test it on their test bences hot and cold,saves all the head fork ;) ;D
Offline OverTheHill
« Reply #6 on: January 09, 2016, 08:54:55 am »
at work we had an almost new one [same model], only weeks old & no spark. Being CDI & us still learning about this 'magic' spark in desperation i replaced all the connectors from the loom to the box & box to top coil etc--just used yamaha crimp on type that we had at work. Anyway, it worked & never looked back luckily for me. Sorry if that's no help 40+ years later lol but 'might' be relevant.
Offline micko
« Reply #7 on: January 09, 2016, 10:11:16 am »
I got a yza that is doing the same thing, pretty sure it is the igniter/pulse coil playing up.
« Last Edit: January 09, 2016, 10:21:09 am by micko »
« Reply #8 on: January 09, 2016, 01:22:53 pm »
check all the leads and connectors - had a wire break inside the outer sheath recently which gave me intermittent spark.
« Reply #9 on: January 18, 2016, 02:22:07 pm »
THrow it in the bin and buy a PVL for it.
