Marketplace
Wanted
PE250T or later bottom end or crank to suit rebuild
All
Topic: PE250T or later bottom end or crank to suit rebuild (Read 11050 times)
Tony.Brown
B-Grade
December 29, 2015, 10:46:25 am »
Hi all, a good friend is looking for either a rebuildable crank but would prefer a whole bottom end to suit his 1980 PE250T.
Anything out there?
Either PM me here or phone or sms me on 0421985762
Regards, Tony.
pecrazy
B-Grade
Re: PE250T or later bottom end or crank to suit rebuild
December 29, 2015, 10:52:39 am »
I have the worlds worst looking PE250 crank here if he cannot find a better one on earth. What is wrong with his?
Tony.Brown
B-Grade
December 29, 2015, 10:54:24 am »
The threaded end is all kinds of f@#*ed up, what's up with yours?
pecrazy
B-Grade
December 29, 2015, 11:01:27 am »
Bearing fell apart, then got a little water damaged but the ends are great.
Tony.Brown
B-Grade
December 29, 2015, 11:04:05 am »
Sounds good, he has a rod kit ordered for his, then discovered the damage, what model it yours from, or doesn't it matter?
pecrazy
B-Grade
December 29, 2015, 11:05:07 am »
1980 PE250 I think the early ones were different.
Tony.Brown
B-Grade
December 29, 2015, 11:09:39 am »
I have sent you a pm.
LWC82PE
Superstar
Reply #7 on:
December 29, 2015, 11:11:44 am »
80-82 PE250 are the same crank, also 80-81 RS250 uses same crank. Try looking on USA ebay for RS250 crank instead. I need a couple myself and its certainly not a PE part that i would go into a panic trying to find. There are many more harder parts to find than this.
Last Edit: December 29, 2015, 11:13:38 am by LWC82PE
Tony.Brown
B-Grade
Reply #8 on:
December 29, 2015, 11:20:35 am »
No panic Leith, I figure there will be plenty of these sitting in sheds of forum members, just rather trust the forum members than going straight to Ebay.
Tony.
BA #63
B-Grade
Reply #9 on:
December 29, 2015, 05:59:50 pm »
complete bike on gumtree wa for a grand then you got lots of spares
I am still the fastest in the pits
Oldfart
B-Grade
Reply #10 on:
December 29, 2015, 06:31:55 pm »
How many do you want ...
Tony.Brown
B-Grade
Reply #11 on:
December 29, 2015, 06:48:48 pm »
Only one required.
Tony.
Oldfart
B-Grade
Reply #12 on:
December 29, 2015, 08:24:07 pm »
Ok can do ....will ring you tommorow early morning ish
Tony.Brown
B-Grade
Reply #13 on:
December 29, 2015, 09:55:45 pm »
Look forward to it oldfart!
Glen08
B-Grade
Reply #14 on:
January 11, 2016, 08:59:45 am »
I'll have a look today ..but I think I have one if your still looking.
All
Marketplace
Wanted
