Author Topic: Four stroke options  (Read 121822 times)
Offline James Lee
Re: Four stroke options
« Reply #135 on: June 23, 2016, 02:57:16 pm »
Heres a pic of my XR600.Ive never really liked them but when my neighbor had this for sale with the gold excell rims I couldnt resist.I fitted CR500 number plates and front guard and a ne old stock stillmotor rear and the doma mufler all of which I had lying around.I rode it in practice at Bidabadaba and it went great but striped 3 gear levers and eventually 2nd let go.Can wait to get it running again.
« Last Edit: June 23, 2016, 05:47:42 pm by James Lee »
« Reply #136 on: June 23, 2016, 05:26:33 pm »
Im just using the stock SP ones,would the 30mm ones be better?Does that mean my front wheel will be 5mm further forward?
Less off set equals more trail, slower, heavier steering, more steering effort required
More off set equals less trail, quicker, lighter steering, less effort required
« Last Edit: June 23, 2016, 05:28:09 pm by LWC82PE »
Offline James Lee
« Reply #137 on: June 23, 2016, 06:01:27 pm »
Ah ok,I thought it would have been the other way round.Proves how much I know.
Heres some action shots of the SPs first outing and my mate on his MT250,We are so lucky to have such an awsome place to ride.
« Last Edit: June 23, 2016, 06:03:23 pm by James Lee »
Offline James Lee
« Reply #138 on: June 23, 2016, 06:04:06 pm »
Offline James Lee
« Reply #139 on: June 23, 2016, 06:04:51 pm »
Offline James Lee
« Reply #140 on: June 23, 2016, 06:05:31 pm »
« Reply #141 on: June 23, 2016, 06:43:38 pm »
Yeah you are not the only one who has thought that.
« Reply #142 on: June 23, 2016, 07:55:29 pm »
must be slippery...never seen an mt 250 step out like that otherwise 8)
Offline James Lee
« Reply #143 on: June 23, 2016, 08:29:43 pm »
That and the fact the back tyre is bald and probably fitted in 1980,its so slow its quite sad really.
« Reply #144 on: June 23, 2016, 08:38:07 pm »
they were a sensational looking disappointment when new....nothing will change over 40 years or so
Offline James Lee
« Reply #145 on: June 23, 2016, 08:41:15 pm »
He really loves it for some reason but I just love riding with him,he really pushes that old thing round and round till he cant hold on any longer.
I pulled the main jet and it has a 160 in it.Im not sure of the size of this PWK but it has a 160 main so saying it maybe a 35mm?Im thinking a 140 main maybe more suited?The needle was on the bottom clip so someone was trying to feed it some data.
the numbers on the carb are G491 AMK2.
Im going to see the shop for a smaller jet tomorrow,any suggestions?
« Reply #146 on: June 23, 2016, 09:05:28 pm »
34mm carbs off tt500's were a good swap over carb for sp370's or if you like pumper carbs a sr500 34mm carb would do and both use the twin cable setup.
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #147 on: June 24, 2016, 09:53:35 am »
Great to see you running the old girl in James. Looks like you're enjoying your handywork  8)
There are pics of the XL on here somewhere, but here's some more.
Since these pics I've modified the brake pedal to run over the footpeg. I've also made a new airbox along with the tail pipe and muffler as I felt the original way I had it was a bit too restrictive.
Offline Momus
« Reply #148 on: June 24, 2016, 10:57:21 am »
Nicely detailed.
If you love it, lube it.
Offline James Lee
« Reply #149 on: June 25, 2016, 07:50:18 am »
WOW,what a nice macine,looks like you have put some hours into that one.What shocks are those?
