Author Topic: Yamaha XT500 head, exhuast pipe  (Read 9043 times)
Offline Curtis
    • japspec.com.au
« on: December 04, 2015, 09:30:27 am »
Head from early XT500, good usable condition $100
Big bore left hand side header pipe $60
Can send picks to your phone  :)
Offline 147
Re: Yamaha XT500 head, exhuast pipe
« Reply #1 on: December 04, 2015, 08:29:54 pm »
does it come with the matching rocker cover?and where are you located?
everyone wins a prize 4 stroke dummy class
Offline Curtis
    • japspec.com.au
« Reply #2 on: December 05, 2015, 02:27:51 pm »
No sorry, it doesn't. Im located in Brunswick Melbourne.
Offline 147
« Reply #3 on: December 05, 2015, 02:41:51 pm »
unfortunately Curtis its worthless as the cam tunnel is line bored with the rocker cover and both are stamped with the same number,if you use unmatched items the cam shaft bearings can sieze.
« Reply #4 on: December 05, 2015, 02:43:23 pm »
ive got a cover that i brought for the rocker arms if that helps that im prepared to sell 147.pm me for details
« Reply #5 on: December 05, 2015, 02:47:45 pm »
if thats the case im sure a light hone would sort that out or put a coat of 3 bond on both gasket surfaces
Offline 147
« Reply #6 on: December 05, 2015, 04:07:26 pm »
thanks for the offer Matt but I don,t do things like that.
« Reply #7 on: December 05, 2015, 05:04:08 pm »
ive got complete heads as well but i only sell the small fin/inlet valve heads
Offline Curtis
    • japspec.com.au
« Reply #8 on: December 05, 2015, 06:50:05 pm »
Interesting, I do understand its line borred, Im running a SR head with the XT cover and had no issues yet?? I guess time will tell  :o
Offline mick25
  • Hunter valley NSW
« Reply #9 on: December 05, 2015, 07:13:16 pm »
I've had the tt500s for 25 years
And Never had a cam bearing seize yet . would be a lot out there with diffrent non matching covers ,
Like some of mine . Can't see why it would seize .
I had dramas with non bearing cam heads where the covers and heads were not matched and when they were tighten down the cam would not spin , because of diffrent clearance .
Offline 147
« Reply #10 on: December 06, 2015, 11:14:47 am »
I guess you could get away with non matching parts most of the time but I have seen one non matching pair that was that far out that the cam would not spin because of bearing crush, Yamaha felt it necessary to number stamp matching head and rocker covers for a good reason,the same reason they stamp the cases.
« Reply #11 on: December 06, 2015, 11:38:35 am »
plasty gauge is a good tool, back in the good old days with no money, a mortgage etc, cam rattling its head off, on the old Honda SL125 everyday to work ride,
surface ground the rocker cover down, figure 8's on wet and dry, plasty gauge check, rub some more, she's good to go, a new cam chain, Aviation sealant, the old SL ran for years, with only advance retard rattle in the points cover.
oh yer ended up cracking the piston in half whilst monoing in 2nd gear  :o loss of power, smoke out the back, rode it home, wacked a piston in it and was happy except for end float in the crank shaft  :-X
Offline jimson
  • Sanctuary point N.S.W
« Reply #12 on: December 08, 2015, 10:00:13 pm »
Will the pipe fit a 1976/77 TT500 ?  :-\ jimson
