Author Topic: Motoplat charging wires  (Read 4677 times)
Offline farmer58za
« on: November 27, 2015, 04:33:28 am »
Hi All
There are 3 charging wires that come out of my Montesa H6 Motoplat stator. As I understand it, these are their ratings and use :
Yellow 35W - headlight
Green 21W - tail light
White 5W - stop light
Is that correct?
David
« Last Edit: November 27, 2015, 04:36:51 am by farmer58za »
Dave's not here man
Offline matcho mick
    • Moto Tumbi
Re: Motoplat charging wires
« Reply #1 on: November 27, 2015, 03:45:19 pm »
sorta ::), they all go up to the h/bar switch, headlite beams are blue & white (out of switch),the green also splits off to the horn,stoplite switch white is straight from the stator,then it pinks out to the stoplite globe (21w),  theres no green at the tailite,only a red (earth??),& a purple (tailite 5w),then again the blue from the ign coil goes into a purple in the headlite,which leads me to think maybe the purples earth,(fugg, Scrivo come on down  :D),err green is headlite/parker globes earth which piggybacks onto coil ,& becomes red (earth) down to the tailite,geezas,i'm now confused, fugg,sticking to ossas!!, :P
HeavenVMX
« Reply #2 on: November 27, 2015, 04:32:37 pm »
If you can wait until tomorrow I can send you a wiring diagram and specs. PM your email
