Author Topic: Sprocket.  (Read 8853 times)
Offline Natroy
Sprocket.
« on: November 15, 2015, 10:12:55 am »
Does anybody know a place where I can get a countershaft sprocket made?
Offline MaxPower
Re: Sprocket.
« Reply #1 on: November 15, 2015, 05:44:28 pm »
Offline matcho mick
    • Moto Tumbi
Re: Sprocket.
« Reply #2 on: November 15, 2015, 06:47:31 pm »
ok,i'll bite,whats it to suit??, :P
Offline Natroy
Re: Sprocket.
« Reply #3 on: November 16, 2015, 04:36:58 pm »
I want a 14T 520 for a 74 Pursang 360. The standard one is 13T. I can get 12T and 11T, but I want to go the other way.
Offline sleepy
Re: Sprocket.
« Reply #4 on: November 16, 2015, 05:32:43 pm »
Got a feeling that a 4 speed Maico has a very similar spline just the Maico is stepped in on one side where the bultaco is stepped out on both sides. Should be able to get a Maico 14t and add a spacer washer.
Just double checked and a Bul and Macio spline are the same.
Offline matcho mick
    • Moto Tumbi
Re: Sprocket.
« Reply #5 on: November 16, 2015, 06:33:56 pm »
14t 520 chain,don't plan on using the k/start ;), :P
Offline KTM47
Re: Sprocket.
« Reply #6 on: November 17, 2015, 11:38:04 am »
Probably JTR (John Titman Racing)
MAICOS RULE DESPITE THE FOOLS
Re: Sprocket.
« Reply #7 on: November 17, 2015, 11:45:44 am »
is it possible to replace the rear sprocket to get the gearing you want, depending on ratio's 1 tooth on the front = about 3 on the rear
Offline Natroy
Re: Sprocket.
« Reply #8 on: November 28, 2015, 11:22:12 am »
Thanks, I'll try that.
Offline Natroy
Re: Sprocket.
« Reply #9 on: November 28, 2015, 06:42:58 pm »
I'm about to go to my brothers place, he has a shed full of Bully bits, I'll see if he has one to spare.
Will report back tonight.
Thank you, EdgyAl.
Offline Natroy
Re: Sprocket.
« Reply #10 on: November 28, 2015, 06:44:56 pm »
Yes. But I have to put another chain on. Trying to do it without that.
Offline Natroy
Re: Sprocket.
« Reply #11 on: November 28, 2015, 06:46:20 pm »
Why?
Offline Natroy
Re: Sprocket.
« Reply #12 on: November 28, 2015, 07:32:23 pm »
Hey Natroy,
I just got back, all the bits are packed away and buried in boxes, couldn't see any 14's,I ran out of time sorry mate.
Maybe be able to look again next weekend.
That's OK. I'm in no hurry.
Offline sleepy
Re: Sprocket.
« Reply #13 on: November 29, 2015, 05:06:18 pm »
If you go to down in size on the rear you only have to shorten chain and if you go back to the original you can join the cut piece back on with a joining link.
The bit about the kickstarter is the fact that with the larger front sprocket the chain will come every close to the kickstarter shaft. If I get a chance I will put a 14 on a motor and check it for you.
Other possibility if you can't get a 14 is put a 14 tooth band onto an old sprocket by machining a 14 blank or something available out and then machine an old Bulto one down, then welding together.
It does get a bit expensive and can soften the case hardening with the welding heat, does work ok I have a 14t Maico done that way.
