Author Topic: RH250 clutch basket  (Read 7040 times)
RH250 clutch basket
« on: November 15, 2015, 02:38:37 am »
Does the RH250 use the same clutch basket as the TM/TS?
one of these?
Part # = 21200-30102
Part Description = GEAR ASSEMBLY,PRIMARY DRIVE
Model Count = 4
TM250J 1972 246 TM250 CHAMPION OFF ROAD
TM250K 1973 246 TM250 CHAMPION OFF ROAD
TM250L 1974 246 TM250 CHAMPION OFF ROAD
TM250M 1975 246 TM250 CHAMPION OFF ROAD
Part # = 21200-30003
Model Count = 13
DS250T 1980 250 DS250 DUAL PURPOSE
TS250A 1976 246 TS250 SAVAGE DUAL SPORT
TS250B 1977 246 TS250 SAVAGE DUAL SPORT
TS250C 1978 246 TS250 SAVAGE DUAL SPORT
TS250J 1972 246 TS250 SAVAGE DUAL SPORT
TS250K 1973 246 TS250 SAVAGE DUAL SPORT
TS250L 1974 246 TS250 SAVAGE DUAL SPORT
TS250M 1975 246 TS250 SAVAGE DUAL SPORT
TS250N 1979 246 TS250 SAVAGE DUAL SPORT
TS250R 1971 246 TS250 SAVAGE DUAL SPORT
TS250T 1980 246 TS250 SAVAGE DUAL SPORT
TS250X 1981 246 TS250 SAVAGE DUAL SPORT
Offline Doc
Re: RH250 clutch basket
« Reply #1 on: November 15, 2015, 09:14:18 am »
'74-'75 RH250 clutch basket 21200-40000 58t
« Reply #2 on: November 15, 2015, 09:19:44 am »
Where did you find that part number?
Do you know if the shock absorber inside it is made up of rubbers like the RM or Springs like TM/TS?
Offline Oldfart
« Reply #3 on: November 15, 2015, 09:20:14 am »
docs all over it RH numbers  all ended in 40000
« Reply #4 on: November 15, 2015, 09:28:23 am »
Yep and don't show up anywhere online/sedder etc
Offline gt96
« Reply #5 on: November 15, 2015, 09:54:45 am »
You can use the basket from the 69 TS250 Savage (21200-16400). Needs to be modified though.
Remove rivets to release from gear. Will reuse original RH gear (straight cut gears as opposed to helical on the TS). The rubber cush things are exactly the same so if you find a new TS basket, the cush rubbers will be good.
Will need to re-rivet the original gear, but before doing so, you will need to machine 7.5mm from the top of the alloy basket to match the RH.
You can also use the inner hub as well but I think 1.5mm material needs to be machined off the base (you need to check that).
Offline Doc
« Reply #7 on: November 15, 2015, 10:01:13 am »
Thanks Doc
so this one has rubbers inside it right?
Part # = 21200-16400
Model Count = 1
TS250 1969 246 TS250 SAVAGE DUAL SPORT
I have never pulled apart a later TM/TS basket but from what i can tell they are just springs, not springs and rubbers.
« Last Edit: November 15, 2015, 10:10:46 am by LWC82PE »
Offline gt96
« Reply #8 on: November 15, 2015, 10:05:06 am »
Rubbers only. No springs.
« Reply #9 on: November 15, 2015, 10:12:49 am »
Ok that's good as i am looking for a rubber cush drive clutch which would allow using a non cush drive rear wheel.
« Reply #10 on: November 15, 2015, 01:52:50 pm »
I know where there's a '75 RH250 clutch basket for sale, has a bike wrapped around it though.
Offline Oldfart
« Reply #11 on: November 15, 2015, 02:26:29 pm »
What sort of coin are we talking of for said bike
Offline 211
« Reply #12 on: November 25, 2015, 10:51:19 pm »
short answer is its nothing like it.
Look to the RM250a for a closer fit
