Author Topic: 78 Magnum rear hub  (Read 7306 times)
78 Magnum rear hub
« on: November 09, 2015, 08:06:59 am »
After hydroblasting by Gippsland soda blast (thanks Dave!) it has become sadly apparent my hub is stuffed. Looking for an uncracked one now. Thanks Jerry
Offline Tony.Brown
Re: 78 Magnum rear hub
« Reply #1 on: November 09, 2015, 10:15:06 am »
The magnesium hubs were very prone to cracking, mine was the same in my '79, I got a '81 aluminium hub for it, and never had a problem after that. The Mag hubs have casting holes in them, that's how you identify them from the alloy ones, I hope I got that the right way around! If not there will be someone far more knowledgeable than me who can correct me.
Tony.
« Reply #2 on: November 09, 2015, 10:52:21 am »
Aha! Thanks Tony. J
Offline paul
« Reply #3 on: November 26, 2015, 07:36:31 am »
ive got a 81 rear hub .but  its got no  steel brake lineing
paul stacker told me once that he could make a new one and heat shrink a new one if your interested the hubs o other than that
.also theres another one here that the brake lineing is a bit loose  !
50 bucks  pick it up
« Reply #4 on: November 26, 2015, 12:05:34 pm »
Thanks Paul but I've managed find one. However if you come across Magnum swingarm please let me know. Thanks Jerry
Offline KTM47
« Reply #5 on: November 26, 2015, 02:34:00 pm »
If anyone is chasing hubs for Maicos front or rear VMX Services in Holland have new remanufactured ones.  They are heavier than standard but a lot stronger.
MAICOS RULE DESPITE THE FOOLS
« Reply #6 on: November 26, 2015, 07:58:02 pm »
269 Euro. Say $500 landed here. Looks very trick. J
