Author Topic: MX250 - DT250 Questions  (Read 4453 times)
Offline Jumpjuly
« on: October 27, 2015, 09:52:35 am »
Hey Guys,
First post since registration and straight into it.
Will an MX250 barrel / head fit on a DT250 of the same year ??
Also what other parts are interchangeable.
thanks !
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Re: MX250 - DT250 Questions
« Reply #1 on: October 27, 2015, 10:18:23 am »
head/ barrel/ gearbox/ clutch all interchangable per year but kickstart shaft diameter changes '75 I think.
Ban BLACK rims NOW
Offline crossedup2
  • Never enough shed time.....
« Reply #2 on: October 27, 2015, 10:36:45 am »
Gearbox / clutch parts go backwards also into RT1-3 and DT1-3 from the MX250 model. Yamaha parts bin is usually pretty interchangeable per each year model or cases type.
Peter B
Offline Jumpjuly
« Reply #3 on: October 27, 2015, 10:36:56 am »
Perfect answer mate ! Any idea if they make an aftermarket pipe for one ? Or is there one I can modify to fit easily ?
Offline crossedup2
« Reply #4 on: October 27, 2015, 10:40:10 am »
What year model are we talking about? 1974/5 ?
Offline cyclegod
  • Sunny PERTH W.A
« Reply #5 on: October 27, 2015, 06:57:48 pm »
Circle-F make a pipe for the MX250A (74) that comes in 2 pieces when you order it, it could fit a DT of the same year
Ban BLACK rims NOW
« Reply #6 on: October 27, 2015, 07:41:07 pm »
Jumpjuly what are you going to use it for , before you start adding pipes and mx parts and spending cash . GMC makes pipes to fit Ive given him mx 250 pipes to copy . The 74\75 dt250 can be ported and a MX head with a larger carb can make a good enduro for its age . B4 you start spending lots of cash look at the suspension first get that sorted and then look for power . Iain
Offline Jumpjuly
« Reply #7 on: October 28, 2015, 12:49:41 pm »
Thanks for the replies, basically I am going to make it into a road / trail bike. Something I can rip through the mountains then hit the fire trails. Im pretty much just chasing mid to top end power.
Ive already replaced the rear shocks with progressive shocks / springs & will be upgrading the front forks to a later model set of XR250 forks with weight suited forks.
Offline Jumpjuly
« Reply #8 on: October 28, 2015, 12:50:02 pm »
Woops 75 model aswell !
Offline Jumpjuly
« Reply #9 on: November 17, 2015, 05:11:16 pm »
I ended up getting a good condition MX Barrel and Head, I also have found a flatside off a late model Yamaha 250 two stroke which I will also be fitting up.
