Author Topic: '88-'89 ATK250  (Read 70727 times)
Offline YUMASTEPSIDE
'88-'89 ATK250
« on: October 18, 2015, 01:55:38 pm »
Anyone got a manual for an 88-89 ATK 250 air cooled ?? or at least a manual or some sort of instructions for the Rotax motors they used in them.This one came in a box along with a complete.....well, pretty much complete.....roller, even has that weird primary sprocket mounted disc brake :o ???
                      Roger
..........come on Nathan, this should interest you !! ;)
Re: '88-'89 ATK250
« Reply #1 on: October 18, 2015, 04:04:26 pm »
Sounds good Roger. I can even get it back to Australia this week.
Thanks!
Re: '88-'89 ATK250
« Reply #2 on: October 23, 2015, 11:50:01 am »
Here's one for a 406, same motor but with a bigger slug ?
http://auto.manualsonline.com/manuals/mfg/atk_motorcycles/406.html?p=21
HeavenVMX
Re: '88-'89 ATK250
« Reply #3 on: October 23, 2015, 09:00:02 pm »
I thought the 250 engine is rotary disc valve while 406 is crank case reed valve?
Offline mustanggrahame
Re: '88-'89 ATK250
« Reply #4 on: October 23, 2015, 09:45:33 pm »
Yes
Re: '88-'89 ATK250
« Reply #5 on: October 24, 2015, 05:50:01 am »
...........correct! thanks for the link, but unfortunately the two motors have different types of induction.
                           Roger
Re: '88-'89 ATK250
« Reply #6 on: October 24, 2015, 11:08:53 am »
Rotax engines don't usually have manuals as such just exploded parts books. Good news is they are similar across the range with many common parts.
Re: '88-'89 ATK250
« Reply #7 on: October 24, 2015, 05:36:47 pm »
............OK,so does someone have an exploded parts diagram book for an '88-'89 ATK250 air cooled?   8) ;) ::)
                    Roger
HeavenVMX
Re: '88-'89 ATK250
« Reply #8 on: October 24, 2015, 06:17:35 pm »
Re: '88-'89 ATK250
« Reply #9 on: October 26, 2015, 06:54:19 pm »
the exploded diagram in the "engine tech notes" should be very close for any rotary valve rotax .The gearbox should be the same for a reed valve
thanks for the link
Re: '88-'89 ATK250
« Reply #10 on: September 15, 2016, 09:33:57 pm »
Offline supermotomc
Re: '88-'89 ATK250
« Reply #11 on: November 09, 2016, 11:43:39 am »
Not a problem Disc timing  is the paramount, there  are  3 possible all marked by casting marks, would need to see your Dise to confirm which one is for yours
there early TNT - late Canam  THEN SWM
Re: '88-'89 ATK250
« Reply #12 on: November 09, 2016, 11:56:36 am »
Not sure if this is still needed, original post was over 12 months ago, but I think this is what your looking for Yumastepside..
http://www.atkusa.com/manuals/Rotax/Service/250-406AC%20Rotax%20Repair%20Manual.pdf
