Author Topic: White Brothers Kawasaki  (Read 9814 times)
« on: October 07, 2015, 08:29:18 pm »
« Last Edit: October 07, 2015, 08:42:53 pm by LWC82PE »
Offline Curtis
    • japspec.com.au
Re: White Brothers Kawasaki
« Reply #1 on: October 08, 2015, 09:27:22 am »
Cool, ill have one of everything! ..ahaha
« Reply #2 on: October 08, 2015, 09:09:54 pm »
There's more in 82 and 83 catalogues but i have not scanned it yet.
Offline cloggy
« Reply #3 on: November 15, 2015, 06:13:05 am »
That's a great find
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #4 on: November 15, 2015, 08:18:03 am »
I'm with you on that seeing as I just got me a KLX
« Reply #5 on: November 15, 2015, 09:23:24 am »
It's interesting how White Bros basically said don't go past our 272cc piston, yet Al Baker/FMF offered a 310cc kit
« Reply #6 on: November 15, 2015, 09:55:23 am »
I could never understand why you have to spend all that money on a bike to make it go from new?
« Reply #7 on: November 16, 2015, 09:01:10 am »
'Cos boys have always liked tinkering to make things faster!
Offline Tony.Brown
« Reply #8 on: November 16, 2015, 09:58:46 am »
I will say up front that I have never ridden one of these, but if all reports are true, there was never a better candidate for performance improvements!
« Reply #9 on: November 16, 2015, 10:50:44 am »
they handled nicely and could be ridden fast until real hp was needed. then it was embarrassing
« Reply #10 on: November 16, 2015, 10:59:30 am »
trying to bridge the gap between what we got and the factory boys got!
Offline Momus
« Reply #11 on: November 16, 2015, 01:35:06 pm »
I did a KL engine in the late eighties when l was playing with 2 litre car engines. Used, l think, a 1.00 mm o/s  1100 piston for about 280 cc. I made a big inlet valve by cutting down a blank Manley Ford 2 litre item. I reseated it and ported it and made a 4 stroke emulsion tube carby from an IT 250 34 mm Mikuni. Piece de resistance was the cam. We stellite welded and ground the old Repco Brabham /Wade 161A formula 1 profile on the inlet, something else on the exhaust so the valves didn't touch each other, shortened guides, found some springs. Pipe was quite small bore, down, and with a slow taper megaphone. Probably 30 hp at 10000. Went well.
« Last Edit: November 16, 2015, 05:42:54 pm by Momus »
If you love it, lube it.
Offline Tony.Brown
« Reply #12 on: November 16, 2015, 02:21:00 pm »
Not many people have your engine building skills though Marcus! It would have sounded great.
Tony Brown.
Offline grouty
« Reply #13 on: November 17, 2015, 01:00:59 am »
+ 2mm on the bore with standard stroke will give you 262cc
Once you get up around 300cc plus you then have the "Gearbox made of cheese" issue. I like mine at 262 with the megacycle cam and the MTC piston. Larger pipe and standard carb. It's way better down low (pulls like an XT500), but the main thing is that it has been 100% reliable. I am tempted to build another bigger "hotter" motor, but I cannot see the point.
Thumpers Rule !
