Author Topic: 1982 YZ250 Rear Hub  (Read 2285 times)
Offline VMXSteve
1982 YZ250 Rear Hub
« on: October 04, 2015, 12:41:46 pm »
Anyone have a good condition rear hub for a 1982 YZ250J they want to sell?
YZ250J, KX500B1, XR600RJ, RM250K8, LTZ250K9, DR650SEK9, GSX1400Z, TTR125, GPX250RII, TSX125, TTR50, LTZ50
Offline Ekka
  • Go hard or go home
Re: 1982 YZ250 Rear Hub
« Reply #1 on: October 05, 2015, 06:53:01 pm »
Got a 84 model one
Offline bishboy
  • Toowoomba
« Reply #2 on: October 06, 2015, 08:52:50 pm »
I've got a 81 YZ465 one
Offline rocketfrog
« Reply #3 on: October 07, 2015, 03:20:48 pm »
84 will be Z spoked and 81 465 will be larger hub and brake. 1980 yz250 is the same hub but with smaller axle 1981 yz250 is larger hub the same as 80 and 81 465. This basically means that you are tied to a yz250j rear hub if you want a straight replacement without modifying axles and spacers unfortunately. You could explore the possibility of using the parts offered by Ekka and Bish, but you will probably need to fettle things a little to get it to fit up properly.
