Author Topic: new cz owner looking for cz tools ie clutch and c/case pullers  (Read 4685 times)
hi
i have bought a 1973 cz250 radial which needs resto.i need the special tools to inspect the motor as po said it has been rebuilt x years ago and not used(so new crank case seal at least) i know you can buy them new from the cz dealers but mabe some people have spare ones they dont use.
jim
Re: new cz owner looking for cz tools ie clutch and c/case pullers
« Reply #1 on: October 22, 2008, 07:57:31 pm »
anyone can lend me a set so i can make coppies
jim
eno
« Reply #2 on: October 23, 2008, 09:21:33 am »
I dug around at Cousin Weedy's site and found the following for ya, the item discription are CZGuys words copied & pasted.
I built all my own tools based on photos & measurements retrieved from the bike, the flywheel puller is a must - that took some creative work on a lathe, I got to mk4 version before I got the internal thread right. The clutch spring compressor is worth it for a stress free clutch strip. The case puller is essential, these cases hold together very firmly. That socket thing with the two dogs is the clutch basket nut socket - needed.
A-Clutch main puller B-Clutch basket 513 C-Clutch basket holder D&E-Basket holder 513 F-???-513 G-Homemade BIG splitter H-Allen wrench I-Late splitter with puller and inserts for clutch basket nut J-Internal rotor flywheel pullers K-? Looked bigger on ebay L-Steering head tool / spoke wrench M-Not sure-clutch tool in cojunction with A, I think. N-Jets O-Flywheel and early primary gear puller P-Clutch basket nut tool Q-Older splitter R-Homemade compressor S-clutch spring compressor
