Author Topic: Cabmkr's MX250B Project  (Read 4351 times)
Offline Cabmkr
« on: September 23, 2015, 10:48:19 am »
Here is what I am starting with.
Looks like most of the important bits are there and it had new piston and rings in the 80's is what I was told. a retired fella has it so it sounds like he may be the first or 2nd owner. Her had it listed as a 74 but serial number is 509-00500. Bike is about 6.5 hours from me but me mum is picking it up which gets it about an hour and a half closer.
« Last Edit: September 23, 2015, 08:45:26 pm by Cabmkr »
Current rides/projects 75 MX125B, 75 TY250B, 75 Carabella Rally 175, 76 TT500 Ice bike, 78 IT400E 79 CB750F , 81 XS650H Street Tracker, 81 YZ250H X2, 93 DS80
Re: Cabmkr's YZ250C Project
« Reply #1 on: September 23, 2015, 02:26:11 pm »
Its a MX250 B 1975 not a 76 yzc . still a good bike though . Iain
Offline Cabmkr
« Reply #2 on: September 23, 2015, 08:37:37 pm »
That would technically be better as I wanted a bike for pre 75 but I figured I could get away with it here in Canada as they just want to get more guys out. This is only the 2nd early monoshock I have seen in a few years on Kijiji.
I was told the serial number is "  the serial no on engine and frame is 509 000500  " and by the angle of the motor and the curve of the clutch cover made me believe it was a YZC, but now that I look at pics of the MXB it matches it and would make more sense.... I would think that makes it a bit easier for parts. And I guess no alloy tank  :(   The Serial number listing I was looking at was just for YZ's and the YZC starts with 509-100101
Thanks for the info!  :) :) :)
Re: Cabmkr's MX250B Project
« Reply #3 on: September 23, 2015, 09:53:24 pm »
Apart from the travel and Air forks , swing arm , they were just about the same . the mx did have a alloy tank though . I might be a little of but I think the gearing and porting were slightly different too . Your right with the 509 000101 was the first mxb250 and when Yamaha has a almost no change model they re start with xxx 100101 for the next model . same with the 400 mx to the 76 yz  and the 74 125 a to 75 125yz b . Iain . Give me a pm I have a few spare bits . Ps the alloy gear shift lever is worth its wait in  gold, pure unnotainium .
« Last Edit: September 23, 2015, 09:56:32 pm by Iain Cameron »
Offline Cabmkr
« Reply #4 on: September 23, 2015, 11:12:46 pm »
    I seen the shift lever, I figured it and the tank if its alloy should cover the cost of the bike. Would you know the difference in the travel between a YZA and the MXB?
