Author Topic: white Lithium grease in spray can  (Read 5254 times)
Offline chrisdespo
« on: September 21, 2015, 10:53:02 am »
Hi Guys, had the sales rep around from Dymark paints and thing the other day he dropped of a few sample cans of some products thought this may be of interest. I have always used white lithium grease on axles and swing arm bolts  when fitting seems to stop the siezes, also used on outboard motors and the guys on the water board at work use it in sewerage pumps for the same reason.
when we had the yamaha and kawa shop in hervey bay the bikes we all took to the island (fraser island) unless this was used would always come back with axles and thing stuck fast well after they had been sitting in the shed for a month or so. must say i always cleaned mine properly when we go home. have been fiddeling with a can for a week or so and its a real good way to have it packed if you get a chance grab a can and give it a go seems to be a pretty good product.
When in DOUBT GAS IT!!!
Re: white Lithium grease in spray can
« Reply #1 on: September 22, 2015, 04:39:34 pm »
wd40 do the same thing and it works well ;)
Offline chrisdespo
« Reply #2 on: October 25, 2015, 07:25:41 am »
No WD40 doesn't do the same thing.
« Reply #3 on: October 25, 2015, 08:02:21 am »
I use the same product on my stearing cable on my boat but not the spray in a small tub (whitworths boat supplies) never had one seize in 20years only 2 boats in that time and still have one of them never thought about using it on a bike might try on the new build.
I use it as salt makes most grease go hard and also it dosent wash away in the water
« Reply #4 on: October 25, 2015, 12:45:36 pm »
wd40 make lithium grease in a spray can
Offline chrisdespo
« Reply #5 on: November 02, 2015, 01:23:19 pm »
never seen the WD version probably just as good. id never seen this product
Offline FourstrokeForever
  • AKA Mark H #35 VCM
« Reply #6 on: November 03, 2015, 01:51:52 pm »
I've been using CRC Lithium grease in a spray can for years and I've never had a seized axle or swing arm axle since. Works well on brake cams as well.
