Clubroom
Tech Talk
Tapered steering bearing conversion
Topic: Tapered steering bearing conversion (Read 4204 times)
skypig
September 06, 2015, 01:29:05 am »
I bought an All Balls kit for my RM125X
Instructions include: turning down the stem!
Can the stem be pressed out? Or do you need a lathe big enough to spin the bottom triple clamp (scary propersition)
Anyone done it?
Lozza
Re: Tapered steering bearing conversion
September 06, 2015, 07:59:02 am »
Many times .Easy peasy with the bottom clamp attached, the clamp goes toward the tailstock
smed
September 06, 2015, 09:25:31 am »
Quote from: skypig on September 06, 2015, 01:29:05 am
That makes a mockery out of there mantra "Fast,Easy,Complete"
WTF
LWC82PE
Superstar
September 06, 2015, 12:11:55 pm »
The stems do press out.
skypig
Reply #4 on:
September 06, 2015, 03:05:43 pm »
Thanks guys.
I'll get on to it.
William Doe
Reply #5 on:
September 07, 2015, 07:22:53 am »
Press stem out through the bottom , apply a little heat first to help it and it will come out without much fuss .
Clubroom
Tech Talk
