Author Topic: How serious is a cracked rim?  (Read 12869 times)
Offline PEZBerq
  • Brisbane
« on: July 28, 2008, 09:54:19 pm »
Interested in peoples thoughts on this...... ???
How serious are cracked rims and what is the priority during a restoration to repair/replace a rim that has a crack? Does anyone have a tale of woe because of a cracked rear rim - rather than say loose or broken spokes? What happened...did the rim just flat spot  :o :oor or did the wheel collapse :'( :'(  Was there much pain involved :( :(
Is a cracked rim a scrutineering cause for rejection..assuming it is detected?  Is a cracked front rim a bigger danger than a rear rim?
Re: How serious is a cracked rim?
« Reply #1 on: July 29, 2008, 02:41:13 pm »
I have just had a cracked rim TIG welded up last week ...went to all the trouble of removing the spokes ( thought I was doing the right thing ) had to take it back home put all the spokes back and tension up  ???
Informs me the wheel will distort too much .
You can hardly tell it's been repaired - still runs true - no flat spots  :)    $25-00
« Reply #2 on: July 29, 2008, 04:02:54 pm »
or a secondhand rim from the wreckers (if you can find them of course) $50 each for the last two I bought.
Offline PERM250
« Reply #3 on: July 29, 2008, 05:58:59 pm »
hey oldfart where did you get it welded ? and does he do a good job.
Offline mboddy
  • Canberra
« Reply #4 on: July 29, 2008, 06:23:33 pm »
Hey that sounds good.
I have a great wheel but the rim is cracked and so I thought I'd have to throw it away.
Can anyone TIG weld it or is there some skill involved?
Vinduro Penrite Team
Offline PEZBerq
  • Brisbane
« Reply #5 on: July 29, 2008, 10:22:31 pm »
Why try to fix it at all?  Anyone ever hear of someone getting hurt or damaging their bike as a result of dirt riding using a cracked rim - knowingly or unknowlingly?
FYI I was told by a wheel respoking mob today in Albion that they will refuse to re-anodise any rims older than 7 years.  They reckon they are too likely to crack.
« Reply #6 on: July 31, 2008, 11:59:38 am »
I've had a few bikes with cracked rims (stupid mid~late 1970s DIDs...). Always stress me out, and I always end up replacing/fixing them, but the cracks never seem to get worse from one ride to another.
Actually, one rim had a few cracks which I marked. Several events later, the original cracks hadn't grown, but several new cracks had developed...
« Reply #7 on: July 31, 2008, 03:48:50 pm »
We get them welded all the time, clean them up, polish and some times anodise them. They look great and have never caused a problem.
« Reply #8 on: July 31, 2008, 04:05:08 pm »
Slacks Creek  - Hiley street - same side as Motorama Holden .
Doc
« Reply #9 on: July 31, 2008, 08:12:16 pm »
PEZBerq, to answer your question in part..I have never witnessed a known cracked wheel collapse nor have I heard of anyone being injured from such. Someone would have during the course of history no doubt. It stands to reason that anyone with a cracked rim should not go jumping buses but I can't say I've had any wheel collapse cracked or uncracked. Self preservation says ride it 6 to 7 tenths since you know about it. There would be a whole heap of undetected cracked rims in use as we speak but rarely (personally ..never)do you hear of them killing someone on a dirtbike ;)
« Last Edit: July 31, 2008, 08:14:14 pm by Doc »
Offline PEZBerq
  • Brisbane
« Reply #10 on: July 31, 2008, 09:31:58 pm »
Doc
That's what I figured would be the case too but wanted to get others experience.  I'll just monitor the crack and see if it grows much.  I reckon I'm not risking my neck and I certainly wont be jumping buses or doing 100km/hr + at Finke or anything! Vintage bikes and vintage bodies mean sensible speeds ;D ;D ;D  Currently I'm getting the wheels respoked due to badly corroded spokes.  If it needs welding one day I'll get it done with the wheel fully spoked to stop distortion.
Doc
« Reply #11 on: August 01, 2008, 07:07:36 am »
' Doc disclaimer' if the opportunity arrises I'd be inclined to say the sooner the better for the weld as the crack will get bigger maybe getting to a point where it may not longer be weldable. If the wheels are apart now wouldn't it be easier to find another rim and end the problem before it arrises? :-\
Offline Pete Hoey
    • hoey racing
« Reply #12 on: August 03, 2008, 02:21:02 pm »
You have to remember that there are an average of 36 spokes holding the rim together on the inside and a tyre on the outside. So long as the wheel is in good nic(ie spokes not lose) it should be ok.
 I raced my sidecar for several seasons with a crackered rear rim and never had a problem.
MONTESA VR
CZ 380
RM125S
WTW
Offline vandy010
  • #789 MX125a BMCC Brisbane
« Reply #13 on: August 03, 2008, 02:34:02 pm »
when i dismantled this rim from my MX250 front wheel it appeared to only have a slight crack at the weld seam.
this is how i found it a couple of weeks later.
"flat bickie"
« Reply #14 on: August 03, 2008, 02:40:11 pm »
How Serious is a cracked RIM ?
How serious is your well being.
How much insurance would you like to keep you out of hospital, for me i don't trust them .
