Author Topic: centre port XL  (Read 3428 times)
Offline matcho mick
    • Moto Tumbi
centre port XL
« on: August 27, 2015, 08:30:00 pm »
just replacing the head on my TL350,(yep flogged out another one ::)),think this is one of Jimbo's american imports,the rocker spindle pins are one piece (steel),unlike the earlier side port spindles which detach from the outer alloy support housing ,is this normal for the later motors?,also the cams marked with a B,all my other cams are E indexed,(250's are G's),the spindle assembly retaining pins are bloody longer too!,just saying!, :P
Offline FourstrokeForever
  • AKA Mark H #35 VCM
Re: centre port XL
« Reply #1 on: August 30, 2015, 10:45:10 am »
Bite the bullet and go to a roller bearing cam. Then you won't flog out anymore "hard to find good ones" heads. Just sayin.....
Offline matcho mick
    • Moto Tumbi
Re: centre port XL
« Reply #2 on: August 31, 2015, 06:50:00 pm »
yeah,i'm hearing you,but i will do the el cheapo version ,ball roller points end,& needle roller the other end,the middles ok on this one FSF,cheers :P
