Author Topic: crush ring/expansion chamber gasket for DG pipes  (Read 13212 times)
Offline 1983_Enduro_YAMI
« on: August 25, 2015, 07:31:05 pm »
Can't find the crush ring for the DG exhaust....... any material or solution will sort this out?
Thanks,
Jacky
Offline matcho mick
    • Moto Tumbi
Re: crush ring/expansion chamber gasket for DG pipes
« Reply #1 on: August 25, 2015, 11:10:56 pm »
if you mean in the exhaust port,muffler centres keep a range of circular flange gasket rings in odd sizes,might be  a tad thick for tooeys,but check anyway if theres one close to you, :P
Offline Lewis
« Reply #2 on: August 26, 2015, 07:05:07 am »
Jacky,try Repco. Recently needed exhaust gaskets and after trying every bike shop in town I finally tried them. Showed the guy the old gasket,he went out the back and returned with a handful. "How many do you need?" was his reply.  Can't hurt to try them
« Reply #3 on: August 26, 2015, 09:38:14 am »
But the stock crush ring is too big for the DG's exhaust flange.
Offline matcho mick
    • Moto Tumbi
« Reply #4 on: August 26, 2015, 11:44:20 am »
hmmm,what part of "a range of circular flange gaskets in odd sizes" don't you understand Jacky, ???, :P
« Reply #5 on: August 26, 2015, 12:12:16 pm »
Hey Mick, Jacky's just learning mate. He hasn't even started to fossilize yet. He's only 15 ;D
I sold seven of my bikes in the past year. We need fresh blood, if I am to have any chance of selling the rest ;D
Welcome aboard Jacky and good luck with your exhaust mate :)
Offline ITDOG
« Reply #6 on: August 26, 2015, 01:14:19 pm »
Hey Jacky ....I take it your talking about the IT250K??, I just used High heat copper silicone on mine........the standard ring never seals that good even on a new stock exhaust. Just make sure you clean the surfaces with prepsol or brake cleaner etc first
Offline ITDOG
« Reply #7 on: August 26, 2015, 01:20:47 pm »
BTW these are not a flange gasket......more a spigot gasket, an o ring would be more effective perhaps
« Last Edit: August 26, 2015, 01:27:04 pm by ITDOG »
Offline ITDOG
« Reply #8 on: August 26, 2015, 01:39:26 pm »
stopped my leaking DG :)
« Reply #9 on: August 26, 2015, 01:53:27 pm »
Yeah ITDOG, I'm talking about my IT250K
What did you do to stop the DG pipe leaking?
« Reply #10 on: August 26, 2015, 01:55:17 pm »
How did you spray the pipe to make it shiny and nice??
It's a nice bike. I have one in similar condition. Better than the new bikes.
« Reply #11 on: August 26, 2015, 02:06:08 pm »
How good is that 8) 8)
« Reply #12 on: August 26, 2015, 02:42:24 pm »
Where should I smear some of the silicone? exhaust port?
« Reply #13 on: August 26, 2015, 03:34:24 pm »
In the pipe at the step that sits up against the exhaust port, let it sit for about 1/2 hour or so to form a skin then fit to the bike. I do that to my CZ & it's perfectly sealed, my YZ465 which has a DG exhaust needs to be done every few rides though otherwise starts leaking again.
I had to shorten the piece that sits over the exhaust on mine as it was way too long
Offline fred99999au
« Reply #14 on: August 26, 2015, 05:37:55 pm »
And let it cure for 24 hours before you try and start it.
