Author Topic: Montesa sprocket cover  (Read 9420 times)
Offline JAP 454
  • See Ya at the Skids
« on: August 22, 2015, 07:20:12 am »
A mate of mine is looking for a countershaft cover for this Monty, what are his chances ? any help appreciated.
Foss
Offline g465b
Re: Montesa sprocket cover
« Reply #1 on: August 22, 2015, 08:45:46 am »
that model never had one ,  good chance he may have to make one .  g.
Offline JAP 454
« Reply #2 on: August 22, 2015, 08:51:49 am »
Thanks G, I will pass that on, I thought that may have been the case as I had a couple of early Montys back in the dim, dark past. What model do you reckon it is ??
Foss
Offline g465b
« Reply #3 on: August 22, 2015, 09:29:01 am »
 i think its a 72 ' model ,  google   southwest montesa   check the frame and engine numbers with their  model I.D list and pic gallery
cheers g.
HeavenVMX
« Reply #4 on: August 22, 2015, 10:33:52 am »
I think (pretty sure) it may be a '71 125MX well the frame seems to be and some of the running gear. The frame does not fit with a Gray Ghost 250 which had a single tube under the engine and a Husky like side air filter. The 125 & 250 engines from that period do look similar until they are side by side. What a great find
Check the chassis number if it starts with 18M then it is '71 125MX same as engine if it starts with 18M then 125cc
http://motorcycleslog.com/asp/Item.asp?soldid=189763&make=Other+Makes&theday=11%2F29%2F2013
« Last Edit: August 22, 2015, 10:47:58 am by HeavenVMX »
Offline JAP 454
« Reply #5 on: August 22, 2015, 11:14:24 am »
Thanks for your help, lads. The fella that owns it is part of The Old and Rooted MCC, to which I also belong, a longtime friend of mine, he speaks earlyish BMW quite well but not VMX. I have given him the link to this topic.
Foss
HeavenVMX
« Reply #6 on: August 22, 2015, 12:12:33 pm »
You can fit an early 247 Cota side cover to the bike and it has a sprocket cover but makes cleaning mud out difficult. Most people use the centre case extension above the chain run to mount an aluminium sprocket cover over the top chain run and most of the sprocket
Offline cappra
  • Glendale, Arizona
    • Southwest Montesa
« Reply #7 on: August 22, 2015, 01:27:34 pm »
I find it ironic, that in the day,you could not give away an 18M. The bike was too heavy, underpowered and had a 4 speed transmission. The Montesa dealer I worked at had two on the floor that sat for over a year until we slashed the price to $650.00 USD. Now they are collectable! Who knew.....
        Jared
        Southwest Montesa
Offline Brian Watson
  • First Penton in OZ
« Reply #8 on: August 22, 2015, 02:45:32 pm »
Over on this side of the island.. The local dealer Herb Watson..had some countershaft covers cast up..
