Author Topic: Crank pressing jig  (Read 11784 times)
Offline Paul552
  • HEAVEN #552
Crank pressing jig
« on: August 16, 2015, 05:52:26 pm »
Thinking about building a crank pressing jig. Before I do does anyone have one they wanna sell
Offline oz555ktm
Re: Crank pressing jig
« Reply #1 on: August 16, 2015, 05:59:07 pm »
You Can Buy them I will Get back to you Sooon !
Offline Paul552
  • HEAVEN #552
« Reply #2 on: August 16, 2015, 07:02:37 pm »
OK cool please let me know
Offline smed
« Reply #3 on: August 16, 2015, 07:06:48 pm »
Applied racing do one,bloody exxy though,It would not be easy to make though I guess ;) http://appliedrace.com/shop/index.php?main_page=product_info&cPath=47&products_id=1919
Offline Paul552
  • HEAVEN #552
« Reply #4 on: August 16, 2015, 07:31:58 pm »
Thanks smed
That's why im gunna make one. At that price I might make 10  ;D
« Reply #5 on: August 16, 2015, 08:36:25 pm »
Factor in $100 for a copper hammer as well. After your second crank you will realise paying $50 for a rebuild isn't a bad price
Offline tymes
« Reply #6 on: August 16, 2015, 09:31:05 pm »
Do you really need to use a jig? That thing is a lot of money
Offline Momus
« Reply #7 on: August 17, 2015, 12:11:53 am »
One Japanese company who make aftermarket cranks have a simple feature  for getting the initial true of a rebuilt crank very close.
At 180 degrees to the pin bore and about 15 mm in from the edge they drill an 8 or 10 mm hole through each half. This allows you to use a rod of the right diameter to hold alignment as you press.
Given that you are still going to have to true a crank that is carefully pressed, the alignment dowell holes could save a lot of mucking around if they are drilled before disassembly.
If you love it, lube it.
Offline Mike52
  • 81 KTM 125 LC
« Reply #8 on: August 17, 2015, 07:58:31 am »
Old timers used a steel ruler to line the flywheels up and a copper hammer , as mentioned , for the final adjustment.
« Last Edit: August 17, 2015, 08:59:20 am by Mike52 »
Offline Colin Jay
« Reply #9 on: August 17, 2015, 10:39:19 am »
This must make me an "Old Timer", as that is how I was taught to do it, with the only difference being the uses of a lead hammer instead of a copper one. This probably makes me even older since lead has been "dangerous" for years.
CJ
Offline DR500
« Reply #10 on: August 17, 2015, 11:02:44 am »
Press,Vee blocks, dial  gauge and copper hammer  .
Offline Tomas
« Reply #11 on: August 17, 2015, 02:03:36 pm »
Also you should use vernier  or micrometer to measure overal width of crank shaft when pressed together other wise crankshaft may be too loose or too tight in cases when instaled
Offline matcho mick
    • Moto Tumbi
« Reply #12 on: August 17, 2015, 10:24:21 pm »
4' high,2' round hardwood stump,use the other flywheels weight to shift alignment,(i'm talking real flywheels, not them pissy 2 smoke/gokart pizza cutter thingys  :o),as you get close,press them closer together,& repeat,dial guages between centres ,or V blocks for finished dimensions (hopefully),it's a bitch those last couple thou's, ::),& yeah i like the steel ruler,& a scribed mark across the wheels for intial setup,& of course measure the distance the flywheels are apart,
with two stroke cranks if factory alignment/endfloat adjustment shims are present,i tend to delete,the tradeoffs giving the big end more "oil" clearance ,i'm talking 10-20 thou at the most, (ossa's mainly), works for me, :P
« Reply #13 on: August 18, 2015, 11:15:52 pm »
Drilling holes in your crank would upset the balance factor.
Also they would need to be accurately bored to be square to the crank and be a tight fit with the dowels otherwise you would still be spending considerable time with the copper mallet getting it right, just as easy with the old ruler.
With that jig above you would still need another jig to press the crank apart.
