Author Topic: Yamaha Ag 100 rear shock overhaul  (Read 4209 times)
Offline Haysie
« on: August 10, 2015, 05:38:07 pm »
Hi guys,
I have been restoring a 1973 AG 100 and having trouble with the completely removing the rear shock parts. I can remove the top plate and spring but can't remove the bottom plate and height adjuster. I am thinking that the top mounting bolts on to the shock stem. Any tricks to removing the top mount? I have a 1973 Lt100 and it is a different shock altogether.
1973 Yamaha AG100
1981 Yamaha AG175
1985 Honda CT 185
Offline cyclegod
  • Sunny PERTH W.A
    • cyclegod on "youtube"
Ban BLACK rims NOW
Re: Yamaha Ag 100 rear shock overhaul
« Reply #2 on: August 10, 2015, 06:18:42 pm »
Are you sure that the eye screws onto the shaft? Some of the OEM shocks have the eyes welded to the shafts and you can not remove them.
Offline Haysie
« Reply #3 on: August 11, 2015, 09:59:38 pm »
Thanks. Yes I have been looking at replacements as well and it might be cheaper dealing with it that way.
Had a closer look and it doesn't look welded, but it certainly won't budge! I put the shaft in the vice and locked it down good, still won't budge. Looks like new shocks.
Steve
1973 Yamaha AG100
1981 Yamaha AG175
1985 Honda CT 185
« Reply #4 on: August 11, 2015, 10:35:24 pm »
If they are welded you wont necessarily see a 'weld bead'. They are often resistance welded together and it will just look liek 2 parts butt joined together. Even if they are screwed on they will usually have high strength threadlocker and will require a fair bit of heat as well as soft alloy clamps the correct size of the shaft to grip the shaft in a vise. If you can post photo of it then someone may be able to help you more with what you have, if not not take them to a shop or buy some new ones. I would be surprised if an AG100 had rebuildable/serviceable shocks.
Offline Tex
« Reply #5 on: August 12, 2015, 10:38:37 am »
Thanks for the link. I might look into getting some of these for my DT125. Don't you hate it when postage costs more than the product?!  :o
