Author Topic: Wanted YZ125C air boot rubber or complete airbox  (Read 7992 times)
Offline micko
Re: Wanted YZ125C air boot rubber or complete airbox
« Reply #15 on: August 12, 2015, 11:29:09 pm »
Iain, the bell od is 50mm
« Reply #16 on: August 13, 2015, 07:37:05 pm »
Ok I'll get back to you soon . Iain
« Reply #17 on: August 15, 2015, 03:46:17 pm »
Mine is 52mm inside you could use a 2mm rubber strip or make up something . anyway yours if you want it .Iain
Offline Paulos
« Reply #18 on: August 15, 2015, 06:30:24 pm »
... or a 1mm rubber strip.
I'm pretty sure i ran a 30mm carb in the "x" boot originally.  The clamp tightens up well enough to seal it. If you can get your hands on an X barrel and upgrade to a 34mm carb it'd be even better.
« Reply #19 on: August 15, 2015, 06:44:19 pm »
Grey moment haha 1mm either side .
Offline Paulos
« Reply #20 on: August 15, 2015, 09:20:36 pm »
I know your pain  :)
Offline micko
« Reply #21 on: August 15, 2015, 09:40:37 pm »
Thanks guys,Iain I will pm you
