Author Topic: Wanted YZ125C air boot rubber or complete airbox  (Read 7991 times)
Offline micko
« on: August 05, 2015, 10:50:51 pm »
Or any leads where to find/buy
Offline micko
Re: Wanted YZ125C air boot rubber or complete airbox
« Reply #3 on: August 06, 2015, 10:25:38 am »
That's the one, expensive little bugger !
« Reply #4 on: August 06, 2015, 02:54:27 pm »
my first thoughts also!
« Reply #5 on: August 06, 2015, 07:32:34 pm »
Try Speed and sport in the US they are making reproductions . Also Known as Yam top dog .
« Reply #6 on: August 06, 2015, 09:16:03 pm »
Iain - I see they list stock - and significantly cheaper as well - are these the repos?
Rossco
« Reply #7 on: August 06, 2015, 09:18:42 pm »
there is also a guy parting out a 125C on Marks at the moment?
« Reply #8 on: August 07, 2015, 09:24:42 pm »
Rossco Yes they are repo's but their other bits are very good . Micko I'll have a look in the cave this weekend not promising but I think I might have a 125x one if that's the same . Iain
Offline micko
« Reply #9 on: August 07, 2015, 09:43:22 pm »
Cheers guys, much appreciated.
Offline micko
« Reply #10 on: August 07, 2015, 09:58:52 pm »
1G8-14453-00-00   JOINT, AIR CLEANER YZ125X
537-14453-00-00   JOINT, AIR CLEANER YZ125C
Looks the same part number, just different prefix
Offline Paulos
« Reply #11 on: August 07, 2015, 10:22:53 pm »
Different size carby from the c to x, 30 vs 34mm
« Last Edit: August 07, 2015, 10:26:15 pm by Paulos »
« Reply #12 on: August 08, 2015, 05:16:51 pm »
That's the internal size Paulos  , Mick get me a out side dia measurement of the bell .
Offline Paulos
« Reply #13 on: August 08, 2015, 05:50:41 pm »
I think the 28mm and 30mm are the same and the 32 and 34 are the same.
I don't think it'll matter though if you're putting a 30mm carb into an X airbox rubber, might be tricky the other way around though
Offline micko
« Reply #14 on: August 11, 2015, 03:05:33 pm »
ok, I will check tonite
