Author Topic: KLX crank and con rob assembly  (Read 6322 times)
Offline The Stroker
« on: July 08, 2015, 06:17:57 am »
Hi guys
Can anybody supply a second hand crank and con rod assembly for me. Also chasing a 72mm piston.  Sump plug fell out drained oil siezed engine bugger.
Cheers Brett.
Offline yamaico
Re: KLX crank and con rob assembly
« Reply #1 on: July 08, 2015, 07:03:35 am »
Hey Brett,
What model KLX and where are you located?
Pete.
Offline The Stroker
« Reply #2 on: July 08, 2015, 07:14:21 am »
1981 ie no balance shaft. Otherwise i think there all the same. I am on the sunshine coast in QLD.
Offline Curtis
    • japspec.com.au
« Reply #3 on: July 08, 2015, 09:30:28 am »
Iv got a complete spare engine, but im in Melbourne.
Offline grouty
« Reply #4 on: July 10, 2015, 07:49:17 am »
The crank is also the same as the KL250 from the same era. The early 250 road bike was the same too, so long as it is not the leccy start model. The left crank bearing is replaceable too, despite what the manuals say !
72mm pistons are available in the U.S. I use MTC pistons in Florida. There is a guy on ebay selling them. He is super reliable and reasonable too. It takes only a few days for him to ship to the UK. The link below is my supplier Joe Hooper.
http://www.ebay.com/itm/MTC-Kawasaki-KZ1000J-K-M-P-R-Big-Bore-Piston-Kit-1075cc-/380036648246?hash=item587bf30d36&vxp=mtr
If you message him he will sell you just one piston kit. The valve cut outs work perfect for the KLX. The compression goes up a bit too.
Thumpers Rule !
Offline The Stroker
« Reply #5 on: July 13, 2015, 07:32:22 pm »
Thanx for the info Grouty.
I have a kz/road bike engine , not sure what year it is but the crank is different in two aspects ie; the bearing on the cam drive side has a larger id and the shaft on the clutch drive side has a keyway as opposed to a spline on the klx. This engine doesn't have a lecky start but does have a balance shaft. Cheers. Brett
Offline grouty
« Reply #6 on: July 14, 2015, 12:29:13 am »
Should have also said the later balancer shaft motors are different. You may be able to use the crank cheeks and pin from the later engine, and your crank stubs (if they are still good) from your blown up one.
Thumpers Rule !
« Reply #7 on: July 14, 2015, 10:53:23 pm »
Have you seen this?
http://forum.ozvmx.com/index.php?topic=38570.0
RH is to the same models
Part # = 13037-5002
Part Description = CRANKSHAFT,LH
Model Count = 5
KLX250-A1 79 250 KLX250 OFF ROAD
KLX250-A2 80 250 KLX250 OFF ROAD
KL250-A1 78 250 KL250 DUAL PURPOSE
KL250-A1A 78 250 KL250 DUAL PURPOSE
KL250-A2 79 250 KL250 DUAL PURPOSE
The later KLX doesn't come in in my parts list but the crankcase is completely different to the earlier versions
